Can I just have my rotors resurface without..
Old Oct 31, 2005 | 10:02 AM
civic91's Avatar
Default Can I just have my rotors resurface without..
changing my brake pads? Here's my situation, I borrowed my sister's car for 2 weeks. I notice vibration in the steering wheel and brake pedal under braking. So I'm just wondering if I can just resurface the rotor without putting a new brake pads and see if that will help the problem.
Old Oct 31, 2005 | 10:26 AM
TypeRPaul's Avatar
pads are cheap and if u have the rotor off why not replace them, are they new?
Old Oct 31, 2005 | 10:31 AM
civic91's Avatar
Default Re: (TypeRPaul)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRPaul &raquo;</TD></TR><TR><TD CLASS="quote">pads are cheap and if u have the rotor off why not replace them, are they new?</TD></TR></TABLE>
If I replace pads and rotors I will probably spend $100 plus. I just spend $50 yesterday for oil change and tire rotation and balance. This is why I'm asking if I can just resurface the rotors.
Old Oct 31, 2005 | 10:44 AM
low430's Avatar
Default Re: (civic91)
REad this
http://www.stoptech.com/tech_i...html#
If you resurface the rotors and dont replace the pads, Ill just say its a waste of time and money
Old Oct 31, 2005 | 10:50 AM
civic91's Avatar
Default Re: (low430)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by low430 &raquo;</TD></TR><TR><TD CLASS="quote">REad this
If you resurface the rotors and dont replace the pads, Ill just say its a waste of time and money</TD></TR></TABLE>
thanks. that's what I want to know.
Old Nov 1, 2005 | 04:34 AM
93_teg_CT's Avatar
Pad's are like 20 bucks all around at autozone... I don't know how much it is to resurface rotor is though...
Old Nov 1, 2005 | 05:21 AM
Racermech's Avatar
Default Re: (93_teg_CT)
if you are doing the work yourselft you can take the rotors down to autozone/pepboys and it is only $8 per rotor to grind them. New pads are only $20-30. If you have neve your done a brake job yourself it is not hard at all. And it will save you a lot of money
Old Nov 1, 2005 | 06:59 AM
low430's Avatar
Default Re: (Racermech)
when you regrind them you loose brake efficiency, Less mass too store thermal energy means higher disc temperatures
Old Nov 1, 2005 | 07:41 AM
HONDA RR's Avatar
Default Re: Can I just have my rotors resurface without.. (civic91)
Replace both the brake pads and rotors
Old Nov 1, 2005 | 07:47 AM
Muckman's Avatar
Moderator in Chief
It will be fine with the same pads. God you guys are straight by the book arent you.
Old Nov 1, 2005 | 08:44 AM
Racermech's Avatar
Default Re: Can I just have my rotors resurface without.. (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">It will be fine with the same pads. God you guys are straight by the book arent you.</TD></TR></TABLE>
You know my fater in law says the same thing, but i figure pads are so cheap why not do new pads?
Old Nov 1, 2005 | 11:03 AM
Muckman's Avatar
Moderator in Chief
Default Re: Can I just have my rotors resurface without.. (Racermech)
well its obvious the guy is on a tight budget otherwise he would buy new rotors as well.
Old Nov 1, 2005 | 11:15 AM
KP9's Avatar
KP9
you should get new pads
Old Nov 1, 2005 | 11:23 AM
civic91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">well its obvious the guy is on a tight budget otherwise he would buy new rotors as well.</TD></TR></TABLE>
Yes, I'm on very tight budget right now, that's why I'm asking if I can just resurface the rotor. Like I said, the car is not mine, if I put some money on it (which I don't have) I'm not sure if I'm going to get it back. I just want a simple cheap solution.
Old Nov 1, 2005 | 11:27 AM
suzawa94's Avatar
i second that . i do this **** for a living, replacing pads when resurfacing rotors is RECOMMENDED, not NECESSARY.
keep in mind that if rotors are warped enough (excessive runout) resurfacing them might not help, and therefore you have to dish out new rotors
Old Nov 1, 2005 | 04:36 PM
low430's Avatar
Default Re: Can I just have my rotors resurface without.. (suzawa94)
it would be like changing your cam gears and not changing the timing belt..... POINTLESS!!! you can do it but youd be a Diptard if you didnt, plus youll hate yourself when you realize that you just did all that work and the shake comes back.
Old Nov 1, 2005 | 05:46 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic91 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, I'm on very tight budget right now, that's why I'm asking if I can just resurface the rotor. Like I said, the car is not mine, if I put some money on it (which I don't have) I'm not sure if I'm going to get it back. I just want a simple cheap solution.</TD></TR></TABLE>
well, make her pay for it then!
Look at it this way, why does the pedal shake? Because the rotors are warped.
Why should you resurface the rotors? To make them nice and flat again.
But the old pads had worn down to the tune of the warped rotors. Worn pads on perfectly flat rotors will not give optimum braking efficiency. You need new (flat) pads to go with the newly-flattened rotors.
I understand you're on a tight budget, but I just bought new front pads for my Integra for $17 from AutoZone.... lifetime warranty too. A friend resurfaced the rotors for free, but it's pretty cheap to have them done.
Do it right the first time. You'll thank yourself later.
Old Nov 1, 2005 | 05:48 PM
low430's Avatar
Default Re: Can I just have my rotors resurface without.. (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
Do it right the first time. You'll thank yourself later.</TD></TR></TABLE>
x99 /thread
vladd
Aug 2, 2011 01:20 PM
Mikes2000civicsi
10
Jan 14, 2007 04:35 AM
Understeer
Suspension & Brakes
10
Mar 21, 2006 07:08 PM
Takashi1978
May 23, 2005 05:26 PM
weedtank
May 9, 2005 10:23 AM
