just picked up an HF-project ahead
Old Mar 8, 2002 | 07:45 AM
BenenEK's Avatar
Default just picked up an HF-project ahead
I tried to search-no info found-
Just picked up a 91 hf-what exatly am I in for? I have a couple of d16z6's lying around and would like to do a swap. I know I have to change hubs and the wiring harness. any info would be appreciated.
Old Mar 8, 2002 | 07:56 AM
Mugen Dom's Avatar
Default Re: just picked up an HF-project ahead (BenenEK)
depends on how much work u want to do....
u can rewire the hf ecu for obd1 and run the odb1 ecu for that motor... ull also need a tranmission preferably a si tranny... Blown90hatch can help with the rewiring if u dont want to do it ur self. if u do i can give u directions on how to do it ur self... also u will need the harness for the gray plugs off of a 92-95 obd1 motor...teh motor will use the same mounts as the hf so thats easy but the hydro tranny will not work... must be a cable tranny... any thing else u need to know?
know if ur lazy and dont wish to rewire u could run a pm6 the ecu from a 88-91 si and it will run the motor but ulll need something lie a vtec controller to activate vtec. and the fuel mapping wont be where u want it to be. all depends on the amount of work u want to do.
Old Mar 8, 2002 | 08:41 AM
BenenEK's Avatar
Default Re: just picked up an HF-project ahead (jdmB18hatch)
I have the a6 tranny, and all the wiring harnesses I need. I would like to do it the right way. If you would, how do I wire to OBD1?
Old Mar 8, 2002 | 11:04 AM
Mugen Dom's Avatar
if u want to rewire it ur self email me if not im blown90hatch here
u will need a cable d series tranny a hydro will not mount or work with the crx
Old Mar 8, 2002 | 01:08 PM
june's Avatar
Default Re: just picked up an HF-project ahead (Lil Cs Zc)
good luck on your project
hfs are nice
And light!!
t12tninja
Apr 25, 2011 08:03 AM
PnkRokCountryboy
Oct 26, 2006 09:45 PM
O16581724 5 2 5
May 14, 2006 09:13 PM
01IntegraSE
14
Nov 18, 2002 03:46 PM
CivicSiR7
Jan 14, 2002 09:08 PM
