camber kit after coilovers...any suggestions?
Old Oct 31, 2005 | 05:44 AM
chizzadd's Avatar
Default camber kit after coilovers...any suggestions?
i need a camber kit...jus not sure which one to get
i want a nice but inexpensive one....im kinda short on money
any ideas?? please help a brotha out
Old Oct 31, 2005 | 12:27 PM
NCNBPDC5's Avatar
Default Re: camber kit after coilovers...any suggestions? (chizzadd)
i used SPC after i Put on my Tein SS...
Its really just preference...I picked SPC cause they looked beefier than Ingalls...
if i were you i would use one or the other ....spc or ingalls
Old Oct 31, 2005 | 12:44 PM
3vilMonkey!'s Avatar
Default Re: camber kit after coilovers...any suggestions? (NCNBPDC5)
camber kits boooo haaha
Old Oct 31, 2005 | 03:09 PM
chizzadd's Avatar
Default Re: camber kit after coilovers...any suggestions? (3vilMonkey!)
miles! i have to have them, its gonna wear my rear tires if i dont....my rear tires are leaning in which cant be good
Old Nov 1, 2005 | 09:55 PM
shyne's Avatar
well...its not a bad thing to have negative cambers in the rear..
Old Nov 2, 2005 | 06:36 AM
chizzadd's Avatar
Default Re: (shyne)
whys that?....doesnt it wear my tires quicker
and i have some type of "popping" noise coming from the front could it be too low? or what
Old Nov 2, 2005 | 10:55 AM
NCNBPDC5's Avatar
Default Re: (chizzadd)
some negative camber will actually make your car handle better....
tire wear is more a cause of toe than camber...but yes it will wear them if it is extreme
if you have a pillowball...as do most reputable coilovers...there will be popping and slight rattling when you hit things...just cause its metal against metal instead of rubber to metal....
clarify for me...are these adjustable springs or real coilovers....
Old Nov 2, 2005 | 12:20 PM
2CleanGSR's Avatar
Default Re: (NCNBPDC5)
yes i have the same question w/ the camber kit. I am getting neuspeed racing springs that lower 2.25 in the front and 2.0 in the rear. What would be the cheapest kind of kit to get and would i need a full kit or only rear. This would be to save more tread on my tires.
Old Nov 2, 2005 | 12:35 PM
NCNBPDC5's Avatar
Default Re: (2CleanGSR)
dont go for a cheap camber kit....this is kinda like going for cheap cam gears when you get new cams.....just dont do it...
bad analogy i know..lol
Old Nov 2, 2005 | 12:49 PM
Tom5's Avatar
T1R makes a fairly cheap rear kit.
Ingalls for the front is the cheapest.
I would only get the front camber bolts though. The rear wont wear nearly as quick as the front. Dont for get to rotate your tires -> save your tires for a while but will eventually wear down the inside.
Old Nov 2, 2005 | 02:35 PM
Boilermaker1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">if you have a pillowball...as do most reputable coilovers...there will be popping and slight rattling when you hit things...just cause its metal against metal instead of rubber to metal....</TD></TR></TABLE>
Ummm I'm also pretty sure most reputable coilovers DON'T make funny noises when you hit bumps. If your pillowballs make noise when you hit bumps, that sounds like an issue to me. What coilovers that you using that bang around?
The ball should fit tight to the housing with no slop, there should be no movement besides circumferential movement of the steering bearing surface in the housing.
Having used both JIC and Tein camber plates, I've never heard a noise from either.
Anyways, nice and cheap are 2 words that don't match car stuff very well. If you want cheap, buy OBX or something. If you want nice, buy the Hotchkis arms.
SPC is in the middle, I don't recommend Ingalls, they like to sieze from rust very quickly.
Old Nov 2, 2005 | 05:47 PM
chizzadd's Avatar
Default Re: (Boilermaker1)
they are jus the coilovers.....adjustable up to 4", and it seems like its too low but that cant be the problem......(i wish i had the money for full coilovers but its not going to happen with car payments) and being a freshman in college
i want cambers for the rear jus to save a bit of tread you know?.....i'll prolly rotate the tires 2mrw.....jus left front to left rear and same on right, correct?
thanks for the help, keep on coming with it
Old Nov 2, 2005 | 05:54 PM
pon55's Avatar
Boilermaker1 is the man,just listen to what he says!!!!!
Old Nov 2, 2005 | 07:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chizzadd &raquo;</TD></TR><TR><TD CLASS="quote">they are jus the coilovers.....adjustable up to 4", and it seems like its too low but that cant be the problem......(i wish i had the money for full coilovers but its not going to happen with car payments) and being a freshman in college
thanks for the help, keep on coming with it</TD></TR></TABLE>
Well you're going to have to get an alignment. It does you no good just to install them. And be prepared to buy new shocks in about 2 months. Sleeves on Stock shocks
Old Nov 2, 2005 | 07:33 PM
chizzadd's Avatar
yes i know...
im looking for a place to get an alignment right now
Old Nov 2, 2005 | 08:28 PM
NCNBPDC5's Avatar
i guess that did sounds wrong...i shoudl reclarify...
i have Teins....my pillowballs...if you hit a bump ...more like massive potholes will make a very light pop...just from the tophats rebounding and hitting the metal of the car....
I have heard it from multiple Teins.....its not the actualy ball that i am describing...if the acutally ball makes that sound you need to relube.....
Old Nov 3, 2005 | 03:55 PM
BarracksSi's Avatar
Camber wear is minimized if you have the TOE aligned to zero degrees. I had a set of tires go for nearly a year with almost no camber wear -- sold 'em when I went 5-lug.
Camber adjustments make your car handle differently, not necessarily "better". More camber in the rear holds the back end in place better, which can also be described as increasing understeer.
Anyway...
SPC has gotten the most recommendations that I've heard so far. Ingalls has come out with a new camber kit for the rear made of forged parts -- that looks interesting.
Old Nov 3, 2005 | 04:20 PM
chizzadd's Avatar
Default Re: (BarracksSi)
oh isee...but i'll look around
i dont have all the money in the world right now to get them....soooo we'll see what ican do
maybe you guys have afew tricks or connections to get them a bit cheaper
(2004 civic 2dr) holllllar
blackccoupe
Suspension & Brakes
12
Oct 18, 2009 03:53 PM
CHAMPwhteEK
Suspension & Brakes
Jul 7, 2009 03:22 PM
3Rd GeAr PuLl
Feb 2, 2007 05:32 AM
drumminforev
33
Apr 7, 2006 02:02 PM
Racerage1
Jun 14, 2003 11:33 PM
