Will Aftermarket Rear LCA's correct camber issues?
I am looking into possibly getting some aftermarket LCA's on my ej8. I am curious if by doing this i will correct some camber issues i have in the rear. More precisely, i know that SRR's LCA's are shorter than stock. Will this therefore pull the bottom of the wheel in, therefore correcting a camber issue? thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrCivic98 »</TD></TR><TR><TD CLASS="quote">I am looking into possibly getting some aftermarket LCA's on my ej8. I am curious if by doing this i will correct some camber issues i have in the rear. More precisely, i know that SRR's LCA's are shorter than stock. Will this therefore pull the bottom of the wheel in, therefore correcting a camber issue? thanks!</TD></TR></TABLE>
Yes some do, but this is about the worst way to correct camber as you are messing with your suspension geometry by pulling in the rear tires and effectively narrowing your rear track.
EK k kay
Suspension & Brakes
May 17, 2005 09:39 AM
