Will Y21 gears put in a S80 tranny work?
Old Oct 31, 2005 | 02:42 AM
Pompiuses's Avatar
Default Will Y21 gears put in a S80 tranny work?
Will 4th and 5th gears taken from a Y21 tranny (civic si) fit into my ITR S80 tranny with no problems?
Modified by Pompiuses at 12:02 PM 10/31/2005
Old Oct 31, 2005 | 09:55 AM
chad's Avatar
Moderator
Default Re: Will Y21 gears put in a S80 tranny work? (Pompiuses)
yes....they are the same gears...why?
Old Oct 31, 2005 | 10:54 PM
Pompiuses's Avatar
Default Re: Will Y21 gears put in a S80 tranny work? (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">yes....they are the same gears...why?</TD></TR></TABLE>
Because I just had them installed into my S80 tranny.... Now there's a howling sound coming from the tranny in 4th and 5th gear . Sounds almost like straight cut gears. I guess the clearances are too tight?
Old Nov 1, 2005 | 09:44 AM
Circuit Star-29's Avatar
How bad is the howling? After rebuilding my tranny I get a littl bit of that in 4th and 5th also. Didn't change gears...
Old Nov 1, 2005 | 09:58 AM
Pompiuses's Avatar
Default Re: Will Y21 gears put in a S80 tranny work? (C-speed Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-speed Racer &raquo;</TD></TR><TR><TD CLASS="quote">How bad is the howling? After rebuilding my tranny I get a littl bit of that in 4th and 5th also. Didn't change gears...</TD></TR></TABLE>
If you've ever heard straight cut gears you'd kow it's pretty bad.
I just drained my tranny fluid and even tough the tranny only have 400km on it since the rebuild there was a lot of metal shavings in the oil. My magnetic drain plug was also thick with shavings as well . So it looks like the clearances between the gears are too tight, so their grinding to each other.
I find that strange because the Y21 gears are supposed to fit into the S80 with no problem.... I bought the gears brand new as well. So why are the gears grinding??
delsol revolution
May 2, 2007 08:08 PM
bseries_beast
Jul 24, 2006 12:20 PM
rapgonrn
Feb 2, 2006 06:13 AM
Ideal
Oct 20, 2005 12:56 PM
Intercooled JRSC
Oct 16, 2004 04:15 AM
