Tire question !!!
I have a 97 civic ex and i just installed some h&r springs on my car... well my quesiton is why my car is ballin the tires from the inside, but my friend has the same car with the same drop (springs) but his front is not cambering.. Now i know if you drop your car most of the time you will need a camber kit... well his tires are wearing fine and mine are not!! could IT BE that because his tire is wider then mine?? his tire seems alot wider compared to my falcon's zexs. btw these are both 17s?? thanks in advance
did you put the thicker springs in the front not the back i did this by accident and the front was slammed cause of the pounds or whatever its called.also maybe you need new shocks that there causing the car to drop even more.
hawksftball2007
11
Feb 20, 2012 10:25 AM
