Suspension & Brakes Theory, alignment, spring rates....
drag setup
Old Oct 31, 2005 | 12:11 AM
joeyblow's Avatar
Default drag setup
for drag racing suspension setup should i use 1000 lb spring in the rear only? because i heard it should be stiff in the rear and loose in the front, or is that not true and should i do 100lb all around? any help is appreicated.
Old Oct 31, 2005 | 06:08 PM
Lo-Buck EF's Avatar
1000in/lb rear, softer front, traction bars, limit straps
Old Oct 31, 2005 | 06:15 PM
PIC Performance's Avatar
Default Re: drag setup (joeyblow)
Yes, if you are strictly talking about the springs, then you only have to concentrate in the rears. You definitely do not need 1000lbs springs in the fonts.
jamaljbenoit
Mar 14, 2012 01:04 PM
dubstackz
Suspension & Brakes
Aug 7, 2009 04:49 PM
nycvr6
Mar 1, 2005 07:21 AM
Luke J
Suspension & Brakes
49
Feb 2, 2005 08:40 PM
93EH6
Feb 20, 2003 10:27 AM
