internal tranny swap???
Is it possible to put the full internals of a hydro tranny into the casing of a cable tranny. You would think its possible correct. Ive searched and cant come up with anything. I jess blew my cable j1 tranny and want to put new gears from a hydro tranny.. POSSIBLE??? thanks for the input
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by not so civic »</TD></TR><TR><TD CLASS="quote">you need a '92-93 cable casing and you can do what you mentioned.</TD></TR></TABLE>yes this is true but depending on the diff you use theres a little clearenceing that has to be done to the casing also (if you use a hydro diff)
From: gravity rides everything...everything will fall, se GA/ne FL
you mean gsr/itr diff? yeah depending there is some shaving, but isn't a ls/b16 hydro diff the same size as the latter cable trannies or no?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by not so civic »</TD></TR><TR><TD CLASS="quote">you mean gsr/itr diff? yeah depending there is some shaving, but isn't a ls/b16 hydro diff the same size as the latter cable trannies or no? </TD></TR></TABLE>no the hydro diffs are just a little bit beefier
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by not so civic »</TD></TR><TR><TD CLASS="quote">you mean gsr/itr diff? yeah depending there is some shaving, but isn't a ls/b16 hydro diff the same size as the latter cable trannies or no? </TD></TR></TABLE>the ls/b16 diffs, are the same size as the ys1 diffs! the ones that are different are the gsr, and of course the itr lsd diff! if you were to try to put a gsr diff, or a itr lsd in the ys1 case you'll have to shave the ribs in side where the diff sits! if you don't shave those down, the diff will fit but it won't spin!
LSpimpTEC
Jun 15, 2004 07:38 PM
