question on zc motor, tried serach "zc" but to short
i came across a 88 crx hf for 1500$
has a zc motor with crx si transmission
he didnt mention the motor set up to much
im hoping he used the pm6 ecu and has the zc manifolds and didnt just drop in the block and reused ecu/manifolds of the hf.
my question is this zc motor has to be the single cam 1.6 cuase if it was the dual a crx si trans couldnt fit right?
i just saw that posting on CL. i was wondering if it was a SOHC or DOHC too. either way you're gonna have a hard time smogging it if y ou can at all. the guy is only selling it because he cant.
haha read my sig im a smog tech. your an idiot if u fail your own car if ur a smog tech.
just want it to be teh single cam cause i dont want cops to send me to ref, that i cant do anything, id be screwed. its most likely a dohc zc
Modified by Ba4 at 8:32 AM 10/31/2005
Hey I think thats cool your a smog tech. The ZCs came in both SOHC and DOHC. They both are considered D series and drop right into the CRXs. The SOHC is basically a D16a6 (stock CRX SI engine) but with a slightly more agressive cam. They are both great motors. check out.
http://www.thezcr.com is a great website for ZC information, I went ahead and found the page with all the information you should be looking for.
http://www.thezcr.com/forums/showthread.php?t=7334
ENJOY!
~Adam
ENJOY!
~Adam
wats the ecu code for hf crx's?, also is it easy to tell between a hf manifold and a si manifold? (intake) i know hf is alot smaller and cuter. anyone got pictures?
Modified by Ba4 at 4:52 AM 11/1/2005
hondata website says PM8
http://www.hondata.com/techecuid.html
the hf intake arm is HELLA small [and cute]. you'll be able to tell without any pictures...
smog tech eh? is it cool if i contact you in a few months for smog on my car?
