Did a swap and unsure where some things go
Old Oct 30, 2005 | 09:30 PM
Eg6_rAcEr's Avatar
Default Did a swap and unsure where some things go
well i just swaped a 95 gsr motor into my 95 civic hatch useing ths hatch wiring harness and i am unsure of where two plugs go and what hose runs to a port i have. so any help would be appericated
this pulg is on the passenger side next to the throttle body
this one is on the driver side and it comes from part of the harness that goes under the intake maifold
and finally this is a skunk 2 mainfold and i dont know what hose goes into that port.
if any one can help please do soo i need my car running and bump if you view thianks
Old Oct 30, 2005 | 10:19 PM
my_slow_civic's Avatar
Default Re: Did a swap and unsure where some things go (Eg6_rAcEr)
I am pretty sure that bottom plug, goes into the charcoal canister purge control valve. Then, the hose port on the manifold also goes to the valve, and from the valve, to the cansiter. It supplies the vacuum for the EVAP system.
If you look at the vacuum port on top of this manifold, it goes to the valve. The valve is very hard to see though.
Old Oct 31, 2005 | 09:37 AM
Eg6_rAcEr's Avatar
does any one else kno where thses things go. thanks for some help man
Old Oct 31, 2005 | 09:50 AM
Katman's Avatar
you might wanna check out my skunk2 GSR intake manifold install article here:
http://technet.ff-squad.com/how-to/sk2im
...to see where and how the PCV valve is hooked up.
Old Oct 31, 2005 | 01:36 PM
Eg6_rAcEr's Avatar
any one kno where the top pulg goes i need this bad
Old Oct 31, 2005 | 08:13 PM
Eg6_rAcEr's Avatar
i still need help the thread that is 2 above this helped me figure out where the pcv valve goes but what goes into the fixture that the orginal hose hooked up too
Old Nov 1, 2005 | 09:48 AM
Eg6_rAcEr's Avatar
i still nedd help
Old Nov 1, 2005 | 02:59 PM
Eg6_rAcEr's Avatar
i still need help on the top plug
Old Nov 2, 2005 | 05:12 PM
Eg6_rAcEr's Avatar
no one knows where these plugs go
Old Nov 6, 2005 | 08:21 AM
Slamaccord's Avatar
I believe that plug if for the can that sits underneath the oem gsr manifold. Which works with the secondary butterflies. You don't need it since you are running the skunk 2 Mani.
tylergrae
Apr 13, 2014 08:38 AM
bpoweredeg6
Apr 22, 2013 11:10 AM
HogHead
Jul 15, 2008 04:26 AM
Tad
Jul 3, 2004 02:12 AM
Malachi
Aug 26, 2002 10:46 AM
