4th gen rear strut removal
Old Oct 30, 2005 | 08:13 PM
jdmekB18C's Avatar
Default 4th gen rear strut removal
How hard was it for you guys to remove the rear strut? What did you guys do to make it easier? Me and my brother tried but that **** won't come off.
Old Oct 30, 2005 | 08:16 PM
M@'s Avatar
M@
Default Re: 4th gen rear strut removal (jdmekB18C)
Rusted bolts? I'm about to do this, well hopefully, if can get them off.
You need to remove the upper control arm balljoint to get more room. Use a pitman-arm type puller.
Old Oct 30, 2005 | 08:18 PM
jdmekB18C's Avatar
Default Re: 4th gen rear strut removal (M@)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M@ &raquo;</TD></TR><TR><TD CLASS="quote"> Use a pitman-arm type puller.</TD></TR></TABLE>
whats that?
does it matter cause he has 4ws? we tried stepping on the rear disc, but it still wouldn't budge.
Old Oct 30, 2005 | 10:04 PM
SnlpeR's Avatar
unbolt the swaybar endlinks on the knuckle on both sides....and swing the swaybar upwards
youll be able to step on the hub and it will move down a lot more
Old Oct 31, 2005 | 04:11 AM
kulrevon's Avatar
Default Re: (SnlpeR)
I just unbolted the strut and got a bar for leverage to push the lca down. you night have to remove some bolts so the brake line or abs wire isnt in the way. A little ackward to get out but I was by myself so it was hard to hold the lca down and get the strut out at the same time.
it took no more then 20 mins less if you have a lift and air tools.
Old Oct 31, 2005 | 12:30 PM
jdmekB18C's Avatar
Default Re: (kulrevon)
thanx guys. imma try it today and see if we can pull the rear strut off this time. we got the front out easily and figure the rear should be a snap, got a little cocky and found ourself taking 2 1/2 hrs trying to get one strut out.
Old Oct 31, 2005 | 12:53 PM
M@'s Avatar
M@
Did you guys remove the Balljoint on the uppercontrol arm?
thanks
matt
g2tegsown
Jun 20, 2008 07:45 PM
RA062224
Honda Civic (2001 - 2005)
13
Dec 19, 2007 05:29 PM
efhatchster
Feb 6, 2005 09:27 AM
SL!M
Jun 13, 2003 10:28 AM
PhfftLS
Dec 20, 2002 11:42 AM
