pm6 vtec conversion
i just did a d16z6 swap into my 89 si civic i want to either get my ecu re done to run vtec and have vtec fuel curves or pick up a cheap vtec controller that will hook up to my non vtec ecu right now i have a buddy club vcon vtec activater which activates the vtec and lets more air in but not more fuel any help guys?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oregon »</TD></TR><TR><TD CLASS="quote">1st off is the car obd-0 or obd-1 ? </TD></TR></TABLE>
he said he had a 89 civic si, that would make it non-obd....
btw i would just get your pm6 redone, as long as you don't want ac..
xenocron or kenji can do it. even if you dont have ac, the ecu still has a pin for ac that just isnt used. it will probably cost you about $100 or so.. but youll have the confidence that you are running your engine the right way.
the ideal way to run vtec is to do the obd1 conversion...which will give you the best results and tuning freedom. If you are on a budget however you do have different options. One option to look into is to use an rpm activation switch like msd to activate vtec. This will allow you to run vtec while using your stock PM6 ecu. It will run somewhat reliably, but i would recommend that you still have this ecu chipped with at least an ebay "spoon" or "mugen" program. This was my setup when i had a z6 in my EF previous to my b16 swap.
If money is not an issue...by all means opt for the obd0 to obd1 conversion.
If you run turboedit with the vtec triggering option you will have "tuning freedom" and no need to go obd0 unless you want to. You will be able to change your fuel and timing tables. http://www.pgmfi.org
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulangot »</TD></TR><TR><TD CLASS="quote">he said he had a 89 civic si, that would make it non-obd....
P </TD></TR></TABLE>
Wow, your an Idiot
88-91=obd-0
92-95=ond-1
Wow, your an Idiot
88-91=obd-0
92-95=ond-1
Wow, your an Idiot
88-91=obd-0
92-95=ond-1
Wow, you're not much better....
Wow, your an Idiot
88-91=obd-0
92-95=ond-1
Wow, your an Idiot
88-91=obd-0
92-95=ond-1
OBD0 = non-OBD
Wow, your an Idiot
88-91=obd-0
92-95=ond-1
OBD0 = non-OBD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron »</TD></TR><TR><TD CLASS="quote">
OBD0 = non-OBD
You really shouldn't refer to OBD-0 as non-OBD.
OBD simply stands for On Board Diagnostics, which the first-gen ECUs do fairly well. In 1988 the SAE adopted a standardized connector plug and diagnostic test routine, and this was the precursor to OBD-1. It was never really given a formal title to my knowledge, but most refer to it as OBD-0.
OBD0 = non-OBD
92d15b7
Feb 23, 2011 10:37 AM
Magick211
Mar 8, 2005 09:33 AM
89, buddy, club, conversion, crx, diagnostics, ecu, honda, hook, installation, obd0, pm6, si, vcon, vtec
