Mild Steel or Stainless Tubing
Where might I be able to find mild steel or stainless tubing bent on a 3 to 4 inch CLR? Hoping to find something around .100" wall. Any input would be great.
gottcha.
ill check my dies when im back at the shop tomorrow. i think your clr is less than what ive got for an 1.75 die, but ill check. Ive done a few manifolds with the ones ive got but they were all one off applications with no real space constraints.
ill get back to you tuesday.
ok -
the 1.75 die that i own is 6.5 clr. they make a 5.5 clr - 1.75 die set but thats the tightest for that od. ( I would have to order it ) you can get down to 4.5 clr, but its in a 1.5 od die. the 1.5 i have is 5.5 clr.
I have 1/2" through 2" die sets with capacity to 2 1/2" X 120 wall. the bender is more geared towards roll bars, suspension, and header work, anything with a heavier wall requirement. not ideal for intercooler piping but ive done it before, it just rips the 16ga like paper on the larger ods, its just the way its designed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fabrak8rX »</TD></TR><TR><TD CLASS="quote">ok -
What machine are you using? Info link would be great, thanks.
We have those bends in stock good to go
http://www.burnsstainless.com
Gimme a call at the shop on mon if you have any questions
i got it from these guys http://www.vansantent.com/
its a model 4 electric. its was about 2,500 for the base unit, buy the time i got the dies and other teeks figured out, it was around 6k complete. its a handy unit, i cant complain much, ive reworked some things but its been going for a few years now, just normal wear and tear -
psileepR
May 12, 2003 03:09 PM
