need some help on this sway bar question
Old Oct 30, 2005 | 03:13 PM
jpb105079's Avatar
Default need some help on this sway bar question
okay i have a civic with type R control arms in the rear and i wasnt sure which sway bar i could. i'm thinking the swaybar end links mount to the control arm so i would have to get type R sway bars. does anyone know for sure? which sway bar i can use a civic one or type R specific one any advice would help thanks in advance.
Old Oct 30, 2005 | 03:15 PM
Dave_B's Avatar
Try the hybrid forum. You may have better luck there as non of us have probably done this swap into a civic.
Old Oct 30, 2005 | 03:42 PM
jpb105079's Avatar
Default Re: (Dave_B)
thanks for the help.
Old Oct 30, 2005 | 08:57 PM
cxSHOE's Avatar
Default Re: need some help on this sway bar question (jpb105079)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpb105079 &raquo;</TD></TR><TR><TD CLASS="quote">okay i have a civic with type R control arms in the rear and i wasnt sure which sway bar i could. i'm thinking the swaybar end links mount to the control arm so i would have to get type R sway bars. does anyone know for sure? which sway bar i can use a civic one or type R specific one any advice would help thanks in advance.</TD></TR></TABLE>
ill answer it for you.. if you have a 92-95 civic you can use either the civic or the type r rear sway bar on your type r rear lca's. both endlinks will connect to the same spot. and both rear sway bars will fit fine on the rear civic subframe area.
stick with a type r rear swaybar since its bigger than any civic made one (except mugen) and get a bsq kit to help with potential tear out issues (do a search for bsq kit to learn what it is)
Old Oct 31, 2005 | 01:42 PM
jpb105079's Avatar
Default Re: need some help on this sway bar question (cxSHOE)
hey thanks a lot man i had heard that i woulnt be able to use the civic one but thanks for clearing up that problem
Old Oct 31, 2005 | 05:46 PM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpb105079 &raquo;</TD></TR><TR><TD CLASS="quote">hey thanks a lot man i had heard that i woulnt be able to use the civic one but thanks for clearing up that problem </TD></TR></TABLE>
yea as long as the sway is from a 92-95 civic.. the 96+ will not fit.. so like i said just get a type r one since its bigger
blazin415
Suspension & Brakes
16
Oct 2, 2007 04:32 PM
jpb105079
Oct 31, 2005 01:48 PM
sc_92_civic_hatch
Jan 26, 2004 11:47 AM
jdmcivicferio
May 9, 2003 12:57 AM
