flywheel weight ??
Old Mar 8, 2002 | 04:44 AM
jt-sport's Avatar
Default flywheel weight ??
Im sorry if i had post this topic twice ,because i dont know where to post it correctly (on competition forum or tech forum)
Lightening the flywheel
1300 D13b fully mod. with 4 speeds close ratio gear for drag racing ,and also extreme light weight civic body (around 700kg) . anybody knows the best weight for my flywheel, it was 4.5 kg now, I plan more to reduce the custom alumunium flywheel weight (now it was around 4 kg) but there is must be the limit point with the weight to have the best results.
Tell me about the commonly or best flywheel weight for me
Regards
Odie Knownothing
Old Mar 8, 2002 | 05:21 AM
Jesse H's Avatar
Default Re: flywheel weight ?? (jt-sport)
12 lbs is the common/acceptable weight for street
Old Mar 8, 2002 | 05:28 AM
jt-sport's Avatar
ohh.. no , this car was for drag racing use
Im sorry i dont explain it before
Old Mar 8, 2002 | 06:11 AM
rainforest's Avatar
go 6 then you will lose low end tq but you will gain the sweet *** revabillity. d13 sweet dude i want to see what this car runs.
Old Mar 8, 2002 | 06:22 AM
jt-sport's Avatar
Default Re: flywheel weight ?? (rainforest)
Thanks for both of you for the answer
to rainforest : 6 pounds (3 Kg) you means?
[Modified by jt-sport, 3:25 PM 3/8/2002]
Old Mar 12, 2002 | 08:03 AM
jt-sport's Avatar
Default ever try this??
Weapon R make it arround 4 kg. It still had lot cast protussion on the outer rim, and i plan to remove it lil bit, to get the mass as close to the center of rotation as possible. Off course i'll rebalance it after.
But im affraid it will loosen the ring gear for the starter and then fly away from the flywheel while it reving high
anyone ever try that "awfull" works, and still safe until now??
EJ8_Man
Honda CR-V & Element
Dec 6, 2015 03:42 AM
ajbucci
May 20, 2006 09:39 AM
jt-sport
Mar 8, 2002 04:27 AM
