Suspension & Brakes Theory, alignment, spring rates....
crx rack end bushing
Old Oct 30, 2005 | 02:55 PM
work-in-progrex's Avatar
Default crx rack end bushing
i just finished ordering everything new for my front end...wheel bearings.. tie-rod ends- ball joints U&L... control arm bushings, sway bar bushings... all oem... i also ordered new rack bushings... mounting ones, the cushion, and rack end bushing... im sick of shitty feeling in front end,, and i wann get into auto-x next spring, so my question is how exactly do you replace the rack end bushing, i will be puttin on the tie-rod ends this week so im trying to figure out if that is the timw when i should do it... and also is it a bitch to do.. kinda looks that way
thanks
Marc
Old Nov 6, 2005 | 08:31 PM
Tyson's Avatar
Default Re: crx rack end bushing (work-in-progrex)
youll like the improved feeling once you replace the rack end bushing.
https://honda-tech.com/zerothread?id=1117870
https://honda-tech.com/zerothread?id=1387079
Vagitarian
Jun 6, 2012 12:19 PM
sl0waccord
Feb 13, 2012 03:43 PM
coot_er
Nov 22, 2007 07:19 PM
RanCRX
Oct 14, 2007 06:27 AM
work-in-progrex
Nov 5, 2005 02:04 PM
