brake light problem
Our 5 spd 99 accord ex the brake lights stopped working.
the taillights work fine. i checked all the bulbs and they are good and so are the fuses. checked all the connections at the bulbs and they appear to be ok.
the car has 124k it that helps.
any ideas are appreciated. thanks
Modified by montman at 2:37 PM 10/30/2005
Look in the fuse box under the hood. There will be a fuse called brake lights (or something similar). Make sure that is good. If it is, then the problem is most likely the brake switch.
