Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
Collectors, Flanges, Adapter Plates DIY Turbo Equipment. From BmCrace.com
Old Oct 30, 2005 | 12:17 PM
BmCRace.com's Avatar
Default Collectors, Flanges, Adapter Plates DIY Turbo Equipment. From BmCrace.com
Listed below are Honda-Tech specials for November only.
All BMC Race Header and Turbo Flanges are made from 1/2" mild steel, and Precision CNC Machined
Header Flanges:
420 A (Mopar) $34 ea.
4G63 Mitsubishi $32 ea.
4G93 Mitsubishi $34 ea.
A Series Honda $34 ea.
Audi/VW 16V $32 ea.
Audi/VW 20V $34 ea.
Audi 20V 5 Cyl $57 ea.
B Series Acura/Honda (all models) $25 ea.
D Series Honda (all models except D17) $25 ea.
D17 Series Honda $27 ea
F22B1-B2 Series Honda $32 ea.
F20C Series (S2000) Honda $34 ea.
H22 Series Honda $32 ea.
K Series Acura/Honda $32 ea.
LS1 Chevrolet (Corvette) $130 pr.
Porshe 911 Series (Individual) $79 set.
SR20DE Nissan $34 ea.
Acura NSX $79 pr.
Turbo Flanges:
14B (TD05-14B, 16G, and T25 DSM) $16 ea
14B LOG (TD05-14B, 16G, and T25 DSM) $32 ea
CT26 (Toyota) $22 ea
IHI RHB5 (4 Bolt) W/8-1.25MM $16 ea
T25 Garrett (not DSM) W/8-1.25MM $16 ea
T3 Garrett W/10-1.5MM $16 ea
T3 Turbonetics (15% larger port) W/10-1.5MM $17 ea
T3 Log (port matched to I.D. of 1.5" Sch 40 pipe) W/10-1.5MM $30 ea
T3/T4 Universal W/10-1.5MM $22 ea
T3 Volvo $22 ea
T4 (Single Port Design) $20 ea
TD04-13G (smaller out of center port than 14B DSM) $22 ea
TD04L/IHI VF (Subaru incl. WRX/STI 3 bolt) W/10-1.5MM $22 ea
TD06 W/10-1.5MM $22 ea
TD06 Log (port matched to I.D. of 1.5" Sch 40 pipe) W/10-1.5MM $38 ea
TE04H/T3 (Mopar T3)W/10-1.5MM $22 ea
Downpipe Flanges:
14B (TD04-13G, TD05-14B, and T25 DSM) $20 ea
IHI RHB5 (5 Bolt) w/internal wastegate passage $32 ea
IHI (4 Bolt - Subaru) w/internal wastegate passage $32 ea
T25/T28 Garrett (not DSM) w/internal wastegate passage $32 ea
T3 Garrett (Mercedes) 5 bolt $22 ea
T3 Turbonetics (Precision and newer Garrett) 5 bolt $20 ea
T3 Garrett (Saab) 3 bolt $20 ea
T3 Garrett 4 bolt $20 ea
Blow Off Valve Flanges:
Dsm 1 Bov flange (steel or aluminum) $13
Greddy Type R/ Type S (steel or aluminum) $13
Wastegate Flanges:
Tial style 35/38mm Wastegate (threaded) $11
Tial style 35/38mm Dump Tube (unthreaded) $11
Tial style 40mm Wastegate $13
Tial style 40mm Dump Tube $11
Tial style 46mm $16
Collectors:
3" Collector (cut and fitted only, not welded) $40
3" New Turbo Collector (Semi-rectangular outlet to fit T3 inlet, cut and fitted only, not welded) $50
3" Collector (Welded) $80
3" New Turbo Collector (Semi-rectangular outlet to match T3 inlet Welded) $100
3" Collector w/T3 Turbo Flanged (welded) $110
3" New Turbo Collector w/T3 Turbo Flange (Welded) $130
4" Collector (cut and fitted only, not welded) $50
4 New Turbo Collector (Semi-Rectangular outlet to fit t3 inlet, cut and fitted only not welded) $60
4" Collector (welded) $100
4" New Turbo Collector (Semi-Rectangular outlet to match T3 inlet welded) $120
4" Collector w/T3 Turbo Flange (welded) $130
4" New Turbo Collector w/T3 Turbo flange (welded) $150
Adapter Plates:
T25 (DSM) to Garrett T25 (Nissan) $52
T25 (DSM) to T3 $52
14B (DSM) to HF/CX/VX/STD(Honda) $52
T25 Garrett (Nissan) to HF/CX/VX/STD (Honda) $42
T25 Garrett (Nissan) to 14B (DSM) $52
T3 to 14B (DSM) $52
T3 to HF/CX/VX/STD (Honda) $42
T3/IHI RHB5 (4 bolt) $47
IHI RHB5 4 bolt to HF/CX/VX/STD (Honda) $47
IHI 3 bolt (TD04L Subaru) to HF/CX/VX/STD (Honda) $47
IHI RHB5 (4 bolt) to T3 $47
TE04H/T3 (Mopar, Volvo, and Standard T3) to HF/CX/VX/STD (Honda) $52
Some Items may not be in stock and will require machining. Depending on work load, delivery may take 2-4 weeks for machined (out of stock items).
If ordering multiple items, ASK FOR A DISCOUNT!!! For Ordering or if you have any questions please feel free to contact us at.
Shop # 281 856 0400
James Cell # 713 305 9304
Sam Cell # 281 813 0942
jamesgoertz@bmcrace.com
sgoertz@bmcrace.com
Modified by BmCRace.com at 3:35 PM 10/30/2005
Modified by BmCRace.com at 9:46 AM 10/31/2005
Modified by BmCRace.com at 10:04 AM 10/31/2005
Modified by BmCRace.com at 10:36 AM 10/31/2005
Old Oct 31, 2005 | 04:35 PM
Default Re: Collectors, Flanges, Adapter Plates DIY Turbo Equipment. From BmCrace.com (BmCRace.com)
Old Nov 1, 2005 | 10:20 AM
Also for those that dont know,
New products coming soon:
mild steel and stainless slip fit merge collectors
slip fit y pipes
slip fit x pipes
Old Nov 2, 2005 | 07:51 AM
Old Nov 9, 2005 | 02:48 PM
kordenbrock motorsports's Avatar
bump, orders coming soon. thanks again
brett
Manolok20
May 26, 2015 08:16 AM
ekim952522000
Apr 14, 2006 06:32 PM
