First time at the track, SOHC turbo times
Old Oct 30, 2005 | 11:25 AM
pearl's Avatar
Default First time at the track, SOHC turbo times
I have had my car together since March and I figured I should take it to the track now (end of october ) It was pretty cold and I was in street trim. This was my first run down the track EVER.
My setup:
The Motor
d16y7 with 110k miles. <u>Stock motor</u>.
d16z6 intake manifold.
z6/y8 transmisson.
exedy stage 1 clutch.
The Turbo Kit
T3 Super 60.
RC 450cc injectors.
Homemade turbo manifold, external Tial wastegate.
chipped obd1 ecu tuned with CromePRO for 11psi.
I weighed in at 2400 with me in the car.
I was on my street tires (dunlop sp9000's) and I didn't drop the tire pressure.
My twostep was at 3800.
FIRST RUN (my third run was the same EXACT #'s)
R/T .497
60' 2.203
330 6.119
1/8 9.124
MPH 83.20
1000 11.697
1/4 13.87
MPH 103.09
I was pretty suprised when I got my timeslip. For my first time I didn't think I did too bad. I think I could have set my two-step higher and got a better 60 foot. Just thought I'd share.
EDIT:
Modified by japearl at 12:11 AM 11/3/2005
Old Oct 30, 2005 | 11:28 AM
nighttrain33's Avatar
Default Re: First time at the track, SOHC turbo times (japearl)
Sounds good to me! Time to build the motor and turn up the boost.
-Shane
Old Oct 30, 2005 | 11:30 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: First time at the track, SOHC turbo times (nighttrain33)
Great time, and a decent 60' too.
Old Oct 30, 2005 | 11:34 AM
pearl's Avatar
Default Re: First time at the track, SOHC turbo times (litterbox)
Do you guys think I could pull more out of it? When I shifted into second I had nothing but spin. It was hard to get second to grab. I think I could knock a few tenths off as well. I think the cold weather was to blame as well for the lack of traction.
About building the motor:
I really want to do the Vitara piston setup. Looks like a really good way to make power.
Old Oct 30, 2005 | 11:37 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japearl &raquo;</TD></TR><TR><TD CLASS="quote">Do you guys think I could pull more out of it? When I shifted into second I had nothing but spin. It was hard to get second to grab. I think I could knock a few tenths off as well. I think the cold weather was to blame as well for the lack of traction. </TD></TR></TABLE>
Lower the tire pressure/dr's/slicks, and run in 70 degree weather and you'll be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japearl &raquo;</TD></TR><TR><TD CLASS="quote">About building the motor:
I really want to do the Vitara piston setup. Looks like a really good way to make power.</TD></TR></TABLE>
What do you mean they look like a good way to make power? Are they higher c/r? I hope not if you are going to boost higher.
-Shane
Old Oct 30, 2005 | 11:39 AM
.Grimace's Avatar
footwork mastery
ya wow 11 pounds but nice man i am doing this soon
Old Oct 30, 2005 | 11:43 AM
Default Re: First time at the track, SOHC turbo times (PurpleEKHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PurpleEKHatch &raquo;</TD></TR><TR><TD CLASS="quote">ya wow 11 pounds but nice man i am doing this soon</TD></TR></TABLE>
I missed that you are running 11 pounds . I'm glad I swapped. Can't wait for the next one .
-Shane
Old Oct 30, 2005 | 11:45 AM
litterbox's Avatar
I'd build a replcement bottom end right now before this one gives.
Old Oct 30, 2005 | 11:48 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">I'd build a replcement bottom end right now before this one gives.</TD></TR></TABLE>
The y7's don't do too badly with boost. It's the pesky y8's that suck ***. But this still wouldn't be a bad idea.
-Shane
Old Oct 30, 2005 | 11:57 AM
Archidictus's Avatar
Unceasing Measure
Awesome times, but I second (third? fourth?) the notion that you'll be wanting a new bottom end before too long if you continue to make passes like that. Nicely done .
Old Oct 30, 2005 | 12:24 PM
pearl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 &raquo;</TD></TR><TR><TD CLASS="quote">What do you mean they look like a good way to make power? Are they higher c/r? I hope not if you are going to boost higher.
-Shane</TD></TR></TABLE>
No, they lower the compression ratio to about 8.5:1 if I'm not mistaken. They are forged too (I think). I plan on building a block over the winter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 &raquo;</TD></TR><TR><TD CLASS="quote">I missed that you are running 11 pounds . I'm glad I swapped. Can't wait for the next one .
11 pounds tuned isn't bad. Why are you glad your swapped? What times did you run in your car?
I have no worries with the block as of right now. The only reason I would build a block is to make more power. If I turned the boost up more I would be more worried, but at 11-12 pounds I feel safe at right now.
Old Oct 30, 2005 | 12:38 PM
EK k kay's Avatar
Great times! I'm in the process of turboing my 99 hatch with a y7/y8 mini me, but with a smaller turbo setup than your 60 trim.
Old Oct 30, 2005 | 12:42 PM
JDM-EJ1's Avatar
Lookin' good!! Now build it and up the boost!!
Old Oct 30, 2005 | 12:43 PM
litterbox's Avatar
Default Re: First time at the track, SOHC turbo times (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">Lookin' good!! Now build it and up the boost!!</TD></TR></TABLE>What's with your new avatar?
Old Oct 30, 2005 | 12:48 PM
EGmikeH22's Avatar
* B A N N E D *
drag radials should get you two tenths
225 45 15s on some 15x7.5s
Old Oct 30, 2005 | 01:06 PM
Default Re: (EGmikeH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds good to me! Time to build the motor and turn up the boost.
Is there an echo?
-Shane
Old Oct 30, 2005 | 01:56 PM
pearl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japearl &raquo;</TD></TR><TR><TD CLASS="quote">11 pounds tuned isn't bad. Why are you glad your swapped? What times did you run in your car?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japearl &raquo;</TD></TR><TR><TD CLASS="quote">11 pounds tuned isn't bad. Why are you glad your swapped? What times did you run in your car?</TD></TR></TABLE>
Old Oct 30, 2005 | 01:57 PM
litterbox's Avatar
He wasn't calling you out man. Calm down.
Old Oct 30, 2005 | 02:02 PM
pearl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">He wasn't calling you out man. Calm down.</TD></TR></TABLE>
The only reason I'm asking is because I was thinking of selling the turbo kit/motor for a swap. Someone has a LS they would be interested in trading straight up. I was debating between a LS/B16 in my hatch too.
turboman's Avatar
11 lbs in a stock sohc!!! Won't be long before you blow the motor. But hey have fun blow the motor then rebuild.
Y8 manifold, gsr throttle body, and 2.5-3 inch exhaust will really do wonders. I havent taken mine to a darp strip but I should some day. Anyways after this summer I got the civic running scary fast.
Old Oct 30, 2005 | 02:07 PM
pearl's Avatar
Default Re: First time at the track, SOHC turbo times (turboman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboman &raquo;</TD></TR><TR><TD CLASS="quote">11 lbs in a stock sohc!!! Won't be long before you blow the motor. But hey have fun blow the motor then rebuild.
Y8 manifold, gsr throttle body, and 2.5-3 inch exhaust will really do wonders. I havent taken mine to a darp strip but I should some day. Anyways after this summer I got the civic running scary fast. </TD></TR></TABLE>
Yeah, the stock TB is killing me.
I know the z6 intake manifold is a lot better than my stock y7 one. Got the z6 for 5 bucks
I'm running a 2.5 inch downpipe/exhaust too. Should have included that before
Old Oct 30, 2005 | 02:18 PM
Civic Racer X 7's Avatar
11 psi on stock internals nice man
Im going to get tuned with teh same setup as you except Y8 manifold in abotu a week 60 trim T/3 I have a 10 psi spring tho and everyone tells me the Y7 wont take it for long
guess we'll see
Old Oct 30, 2005 | 02:20 PM
pearl's Avatar
Default Re: (Civic Racer X 7)
I have been on 10-11 psi for almost 2 months now. I religously beat the **** out of my car all day. I get great gas mileage and I haven't had anything break.
Before it was tuned, I ran a FMU/Missing link for 7 months and also beat the **** out of my car. (march-september) and haven't had anything go wrong. As of right now, I feel that this motor/turbo setup is unbreakable.
Let me know how you make out Civic Racer. I was thinking about getting a y8 head.
Old Oct 30, 2005 | 02:26 PM
blackeg's Avatar
Default Re: (japearl)
times are decent man. very good for 1st time at the track ever. did u go to etown??
if you wanna change the setup, get a different manifold, swap in the ls and bolt back up the turbo kit.
Old Oct 30, 2005 | 02:29 PM
pearl's Avatar
Default Re: (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">times are decent man. very good for 1st time at the track ever. did u go to etown?? </TD></TR></TABLE>
Yes, e-town on a nice cold night.
