12" slim low profile Pusher/Pull Fan $30
Up for sale is one 12" pusher fan that I had previously bought on Honda Tech, item is brand new and never installed. Fan is rated to flow 1550 CFM.
It's slim profile is ideal for use in cars with tight engine space or those in need of extra cooling. It would've gone on my car to replace the AC fan to clear Turbo etc.
You can email me at yum.wong@gmail.com if interested. Shipping will be $10 within continental US. Local Philadelphia area pickup is fine with me.
Original vendor description:
12" 12 Volt High Performance Reversible Electric Cooling Fan Kit. This fan has ten blades, and is only 2 1/2 inches deep. Includes fan, four mounting tabs, and through-the-radiator mounting kit. The blade and shroud are made from Nylon with 30% fiber glass to prevent deformation under high temperature circumstances. Every blade is balanced by the factory. This fan is configured as a puller from the factory; it mounts on the inside and pulls the air through the radiator. However, reversing the blades along with the polarity of the wiring and it becomes a pusher mounted on on the outside and pushing air through the radiator. These are great for OEM or High Performance applications.
Thanks
Thanks
