SPARKS HEADER LEAKING
Old Oct 30, 2005 | 08:46 AM
danxdan's Avatar
Default SPARKS HEADER LEAKING
i have a sparks racing header and today when i looked under my car i could see air moving from right under the header. im guessing thats my header leaking. is that normal to do that or is it something i need to fix. like take it to a welder to weld the leaks. thx guys!
Modified by danxdan at 12:11 PM 10/30/2005
Old Oct 30, 2005 | 11:10 AM
danxdan's Avatar
Default Re: SPARKS HEADER LEAKING (danxdan)
Old Oct 30, 2005 | 04:18 PM
Takumi Fujiwara's Avatar
Where is it leaking exactly?
Old Oct 30, 2005 | 05:04 PM
SpdFrk's Avatar
Default Re: SPARKS HEADER LEAKING (Takumi Fujiwara)
I think he means that its leaking from a spot on the header. Did u happen to bottom out your car or something? or maybe the welds may have cracked open.
Old Oct 31, 2005 | 02:49 AM
xxwhixx's Avatar
does it sound like **** ??
Old Oct 31, 2005 | 01:39 PM
danxdan's Avatar
Default Re: (xxwhixx)
it sounds fine.... and previously it did crack at the weld. at that time i took it to a welder and he welded it back up and put a flex pipe on. everything ran fine and is running fine to this day. but the problem is. i never looked under my car till yesterday. i saw that there were air moving all under the header. maybe about an inch thick. i started to wonder if that was normal or if its something i need to fix.
Old Oct 31, 2005 | 11:47 PM
xxwhixx's Avatar
Default Re: (danxdan)
nope thats not normal it needs a fix somewere
Old Nov 1, 2005 | 11:22 AM
danxdan's Avatar
Old Nov 1, 2005 | 01:30 PM
Combustion Contraption's Avatar
Looks like its known as a low priced copy for a reason.
RedneckRicer
Apr 3, 2008 12:05 PM
YoungKadafi
32
Jun 10, 2006 04:33 PM
JDMlyfestyle
Jul 16, 2004 11:26 PM
iam7head
Dec 3, 2002 11:01 PM
flat-blk-HB
Jun 15, 2002 03:19 AM
