Does My car need to run Warmer?
Old Oct 30, 2005 | 08:38 AM
Hairy Hudson's Avatar
Default Does My car need to run Warmer?
I am in need of help (I think). My car will not idle correct and I think it is because of how cool the motor runs. The temp gauge will never get above the 1/4 mark even in 100 + degree summer traffic. So my first thought is the thermostat any other guess’s or help before I try and make my car run warmer?
Who would of thought that a car could run too cool!
My set up is an:
OBD1 B16A
w/some bolt on parts
w/stock radiator and coolant hoses
Old Oct 30, 2005 | 08:40 AM
Malgerus's Avatar
Default Re: Does My car need to run Warmer? (nateberry103)
It's most likely the thermostat, yes.
Old Oct 30, 2005 | 09:10 AM
Slow ass EF's Avatar
Default Re: Does My car need to run Warmer? (Mr. S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">It's most likely the thermostat, yes.</TD></TR></TABLE>
replace the thermostat and then let us know whats goin on
Old Oct 30, 2005 | 09:37 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Does My car need to run Warmer? (slow *** ef)
The stock temp gauge doesnt tell you anything about the actuall temp of your engine. I bought a autometer one and installed it, and I found that once the car warmed up to 150deg the stock gauge would move 1/4 of an inch and stay there even @ 215 degrees. Get an aftermarket gauge if you really think that your car isnt getting warm enough and then go from there. If there isnt any thermostat then that could be the reason why it wouldnt warm up....
Blaze
Old Oct 30, 2005 | 12:30 PM
Sounds good I am going to pick one up on my way home from work tomorrow. So I will post an update shortly...
Old Nov 1, 2005 | 04:32 PM
I bought the T-Stat today, I totaly forgot yesterday was Trick-Or-Treat day... When I got home today after buying the t-stat My motor felt very warm to the touch. How warm or hot under the hood is normal? I noticed that the warmer the car got (today) the better it idle'd.
I was also doing some searching around in the past topics and posts', i found a idle topic where some guy had simlar issues as me, some on sugessted a fuel injector going bad, not bad yet but going bad... This person also said to check the ohms of the injectors. . .
My injectors are 12.6 (for 3 of them and one at 13.0 Ohms (ODB1 injectors)
I have a older busted set of injectors and the ALL read 11.6 Ohms
Does any one know the disared ohms and what about radiant heat from under the hood after the car is off...
Old Nov 10, 2005 | 10:33 AM
Well I have a new T-Stat in it and it just idles low (almost to the point of a stall out). I am going to mess with the idle speed a little more, if that does not work I am going to try fuel pump ?
Old Nov 10, 2005 | 10:50 AM
g-ride-si's Avatar
did you take out your ac condensor? when i took mine out my car ran very cool. not even 1/4 up the guage.
Old Nov 10, 2005 | 06:52 PM
Default Re: (g-ride-si)
Yup, why would that matter? More air flow than stock or some thing ?
Old Nov 10, 2005 | 06:56 PM
g-ride-si's Avatar
yup. has it been like that since u removed it?
Old Nov 12, 2005 | 05:41 AM
Yeah, did not think about at all till now
Old Nov 14, 2005 | 12:52 PM
g-ride-si's Avatar
did you get that fixed? i just spray painted a piece or cardboard black and wire tied it on there for the winter.
Old Nov 14, 2005 | 01:09 PM
.Noah Fecks's Avatar
do you still have your heater?
Old Nov 14, 2005 | 01:55 PM
p nut's Avatar
Yeah, most likely, your t-stat is stuck open. My old integra had the same symptoms, and a new t-stat took care of it.
Old Nov 14, 2005 | 03:47 PM
Well, I got the car so it will idle with out any thing on like; lights, heater, radio... etc..
When I give the car a load (of current or power) the idle drops below 500RMP and the idles for dear life until I turn some thing off. So I am not thinking that it is the idle speed control motor. Any input would be nice since I dont have the money to just throw parts at it in hopes of fixing something.
I would also like to say thanks for all the help thus far it has been great and very well needed
Old Nov 14, 2005 | 06:47 PM
g-ride-si's Avatar
Default Re: (nateberry103)
are you throwing any codes? could just be weak battery/alternator.
Old Nov 14, 2005 | 07:27 PM
I will stop by my local parts shop on the way home work tomorrow for one of those "free" bat/charging system tests - and then let you know.
Old Nov 14, 2005 | 11:02 PM
ImportHatch's Avatar
Ya a stock temperature gauge does absolutely nothing, thats why they come in the car. Obviously it might not be dead on, but it gives you an idea.
Yager-
Old Nov 15, 2005 | 04:58 PM
I stoped by good old CSK today and my Bat, Alt, and Starter are all ok! So now what? any ideas would be great
I turned the fuel psi up to 47psi from the 42 it has always been at and still no change. The waycky thing is when I take the fuel psi vacume line off the intake manifold the car will ilde high but just fine ? wacky if u ask me...
Old Nov 15, 2005 | 05:26 PM
g-ride-si's Avatar
maybe your vacum lines got crossed, damn my b18 did the same thing and i can remember what it was, im wanting to say i had to clean my iacv, and that fixed it. does the idle still bounce sometimes?
Old Nov 15, 2005 | 06:27 PM
The idle does bounce from time to time... from 1K RPM to 300RPM
How do I clean it out? Just some carb cleaner?
Then as for the vacume lines, any idea as to where I can get the data sheet that shows how they run?
I hate dumb little things like this, If I didn't rack up 70 + miles a day on the car I wouldn't care as much, not to mention in stop and go traffic this SUCKS!
Old Nov 15, 2005 | 06:32 PM
g-ride-si's Avatar
dont know what to tell you about the vacum, look on here at other ppls swaps, i just figured mine out with the old trial/error method.
ya just un bolt it and spray the **** out of it with carb cleaner, in the holes that are on it. thats all i did and it fixed all my idle problems. dry it out the best you can (air hose if you have one) or just shake it out then let it sit for an hr or so.
Old Nov 15, 2005 | 06:55 PM
Cool, I'll try that and I will mess with my vacume lines if that doesn't work
Old Nov 17, 2005 | 12:39 PM
I tried the carb cleaner and it worked great for a day, a buddie of mine told me that I should try just a little (2 or 3 drops) of oil in each hole. I was told oil will work more like a lube and carb cleaner is more like a solvent.
So it looks like the idle speed motor is the issue, if the final clean and lube doesn't work I am going to have to buy a known good one. may just by new OEM from honda and not used. . . .
CDN Yellow ITR
Feb 7, 2008 08:09 AM
chadwick16
May 25, 2006 03:45 AM
HatchedGTI
Feb 10, 2006 10:47 AM
kNOwLedGeDA9
Dec 12, 2005 01:10 PM
SolidSpruce
Jul 22, 2002 07:45 AM
