search is down. need to know LS/vtec wiring info asap!
Old Oct 30, 2005 | 07:23 AM
Acura_I-RS's Avatar
Default search is down. need to know LS/vtec wiring info asap!
vtec sol. is wired up fine. but the opressure sensor, i have heard from soem people you can just ground it out, or? anyone with help, would be appreciated. thanks
Old Oct 30, 2005 | 11:42 PM
ek99's Avatar
Default Re: search is down. need to know LS/vtec wiring info asap! (Acura_I-RS)
Yeah you can just ground it to the head or block, but to make it look stock i would run it to a dead end plug(ground).
Old Nov 2, 2005 | 10:14 AM
jdmcars.com's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acura_I-RS &raquo;</TD></TR><TR><TD CLASS="quote">vtec sol. is wired up fine. but the opressure sensor, i have heard from soem people you can just ground it out, or? anyone with help, would be appreciated. thanks</TD></TR></TABLE>
Depends one what ECU you are using. If you are using one that is looking for VTEC Oil Pressure, you must run the 1 wire to a ground, then the other to the ECU.
What year, what ECU and we can let you know more information.
LsVtecFoti
Dec 6, 2007 11:22 AM
xxghettothixxx
Jun 29, 2007 09:42 PM
ganjasnack
May 26, 2007 06:42 PM
Acura_I-RS
Oct 30, 2005 04:43 PM
PaChiLa Leader
Oct 7, 2005 10:47 AM
