pic of clutch cable connection - auto to manual swap
Old Oct 30, 2005 | 06:07 AM
hb_guy's Avatar
Default pic of clutch cable connection - auto to manual swap
i'm continuing my auto to manual swap today, i just got my pedals, clutch cable and linkage in the mail yesterday. the connection for the clutch cable to the actual clutch pedal seems strange, there isn't a way to securely put the clutch cable on the pedal. am i missing a part? can someone post a pic of what it is supposed to look like to see if i am missing a part? i can also take a pic and email someone so they may be able to help me. suncay is my only day off and i want to take full advantage of it. thanks guys
Old Oct 30, 2005 | 06:26 AM
SVOboy's Avatar
Bump while I run out to look at the pedal assembly in my garage, I'm planning a swap also.
Old Oct 30, 2005 | 06:28 AM
SVOboy's Avatar
I think it just hooks right over the little knobbed in section at the very top of the clutch pedal piece.
Old Oct 30, 2005 | 09:17 AM
hb_guy's Avatar
Default Re: (SVOboy)
then its safe to assume that it just gets tension when you hook it to the tranny?
Old Oct 30, 2005 | 09:59 AM
SVOboy's Avatar
I can't remember where I read this, but it's sposed to be tight when it's attached without the clutch pushed in. Some guy left it loose with the clutch out and when he started it up with the clutch in it only took up the slack and instead of disengaging the clutch, it did nothing and the car almost jumped into his living room. So just make sure it is pulled tight with the clutch out, so when you depress the pedal it will disengage the clutch.
Old Oct 30, 2005 | 10:41 AM
hb_guy's Avatar
thanks for the info-glad i am not missing any parts
Old Oct 30, 2005 | 10:58 AM
SVOboy's Avatar
Good luck, lemme know how it turns out.
Old Oct 30, 2005 | 11:07 AM
nitrofish420's Avatar
The cable shouldn't be adjusted too tight. You should have a small amount of freeplay at the pedal before it actually starts to pull the cable. Check a manual for the exact spec, but it should be something like 1/4-1/2".
Old Oct 30, 2005 | 12:17 PM
hb_guy's Avatar
Default Re: (nitrofish420)
thanks 420
Old Oct 30, 2005 | 12:22 PM
SVOboy's Avatar
Damn, 420's a lot, what tranny are you gonna use, si? That might cost more than my free/20 dollar tranny.
Old Oct 30, 2005 | 12:38 PM
hb_guy's Avatar
yup, si tranny
bmxtrev
May 20, 2011 09:01 PM
hb_guy
Oct 31, 2005 03:43 AM
vegaskurt
Mar 29, 2005 04:01 PM
See Are X
Apr 25, 2002 05:04 PM
