Physical difference between Peak/Hold and Saturated Injector Clips (please help - search down)
Old Oct 30, 2005 | 04:14 AM
7rrivera7's Avatar
Default Physical difference between Peak/Hold and Saturated Injector Clips (please help - search down)
Can I assume Peak & Hold injectors will only fit on ODB0 injector clips while Saturated will only fit ODB1 clips? Is this safe or can I put an ohmeter across the contacts to check their resistance and decide this way?
I know that with the saturated, I have to eliminate the resister box on my CRX and do some weird wiring which I have to research.
I just don't want to fry my ECU down the line because I've read if you mix the wrong injectors with/without a resister box, it will work for a while but eventually crap out
Old Oct 30, 2005 | 04:45 AM
rainforest's Avatar
Default Re: Physical difference between Peak/Hold and Saturated Injector Clips (7rrivera7)
check resistance its the most surefire way of testing. you cant mess out checking them that way
Old Oct 30, 2005 | 01:15 PM
7rrivera7's Avatar
Default Re: Physical difference between Peak/Hold and Saturated Injector Clips (rainforest)
Any ideas on the connectors?
Old Nov 2, 2005 | 02:38 AM
7rrivera7's Avatar
ttt
Old Nov 9, 2005 | 02:48 PM
7rrivera7's Avatar
Can I tell by the injector connectors?
98.4DR.EK.D16
25
Jul 3, 2012 12:27 PM
blkb18
May 18, 2008 05:42 PM
Panoply
Jul 19, 2005 01:37 PM
Panoply
Jul 18, 2005 09:36 AM
ncervantes
Jan 10, 2005 11:15 AM
