H22 in a 1996 Accord (vacuum help?)
Hey I have a 1996 Accord, im in the process of doing a h22 swap into it. I finished everything up but now i have a few questions.
Where can i find the oil pressure sensor wire off the stock accord wiring harness?
Another question is does anyone have the full vacuum line diragram for h22 into an accord. Or if not how will i get this done. There are 2 vaccum lines that i need to get hooked up but i dont know where they should go.
#1. The first line is the one that suppost to come off of the throttle body, where does that one run into?
#2. There is an soleniod that is located near the battery, and the vacuum line runs to the firewall right behind the top of the intake manifold. I dont know where the vacuum line suppost to run after that. I have a open vacuum line near the driver side shock tower. Could that be where it should go into?
pictures or comments will greatly be apperciated.
Note: I tried to do a search but the search feature is currently disabled. So if anyone has a link to this please send it over here.
