WHAT HEAD IS BETTER FOR LS/VTEC
Old Mar 7, 2002 | 11:14 PM
z crx z vtec z's Avatar
Default WHAT HEAD IS BETTER FOR LS/VTEC
im doin ls/vtec convesion i wanna know whut head is better!!
Old Mar 8, 2002 | 12:36 AM
Default Re: WHAT HEAD IS BETTER FOR LS/VTEC (z crx z vtec z)
lets get sum votes
Old Mar 8, 2002 | 02:23 AM
Arturbo's Avatar
Better than steak
25 Year Member
Why must you post this in other forums? One poll is just fine.
Old Mar 8, 2002 | 07:44 AM
Default Re: WHAT HEAD IS BETTER FOR LS/VTEC (Arturbo)
im tryin to0 get sum responses
Old Mar 8, 2002 | 08:11 AM
Homer_Simpson's Avatar
GSR head
Old Mar 8, 2002 | 03:40 PM
KraZyCHOWMEIN's Avatar
exactly, f*ck the head.... get a B20Z cylinder head, the B20 head flows better then a stock LS head
but head from any gurl is good
Old Mar 9, 2002 | 01:25 AM
far's Avatar
far
Default Re: WHAT HEAD IS BETTER FOR LS/VTEC (KraZyCHOWMEIN)
wont the b16 head give him more compression??? i dont know where im getting this from but im sure ive herd it before
Old Mar 9, 2002 | 04:37 AM
under_psi's Avatar
Default Re: WHAT HEAD IS BETTER FOR LS/VTEC (98tegsr)
the B18C(1) GSR head will give the most compression and hence more gains..
B16A head would be best due to the cost
B18C(5) typeR head just plain costs too much...same dimensions as B16A head so just get that and get it ported and change the valvetrain
B17A, good luck finding one...pretty much same as B16A
Old Mar 9, 2002 | 05:13 AM
Some Gook with a DC2's Avatar
from what i heard the b16a heads are better than b18c1 for flow reasons or some sh*t like that. thats what i heard and remember, correct me if im wrong.
Old Mar 9, 2002 | 05:19 AM
under_psi's Avatar
Default Re: WHAT HEAD IS BETTER FOR LS/VTEC (Some ****)
you're wrong
stock for stock a GSR head flows better and makes higher compression then a B16A head. people tend to go with the B16A head becasue it's cheaper/easier to find, considering the B16A was around for over a decade...besides, who in thier right mind would sell you a GSR head off of a perfectly good GSR engine
Old Mar 9, 2002 | 05:24 AM
mycronman's Avatar
ok i got a question about it now too.
how easy is it? does the head bolt right on? I got a 96 civ EX and im planning on getting a b18b w/turbo. should i just say screw LS/VTEC and just turbo the b18b? does vtec even matter at that point? Thanks fellas!
Old Mar 9, 2002 | 05:45 AM
under_psi's Avatar
Default Re: WHAT HEAD IS BETTER FOR LS/VTEC (mycronman)
do not attempt to build an ls/vtec or cr/vtec if you are not willing to dish out some major cash for a complete build up...I won't go into details but I'm building a cr/vtec right now and it is hard on the wallet!
the way I see it, you either go turbo OR frankenstien....both is kinda pushing it(unless you have cash comming out your a$$)...
you can make very impressive hp and tq#s with a boosted B18B...eventually, that will need to built up too though
I say go N/A...but that's me
Old Mar 9, 2002 | 11:08 AM
randyman's Avatar
New User
Default Re: WHAT HEAD IS BETTER FOR LS/VTEC (T.O.tegs)
yup. i've been fasting for a month now. hehehe! and as far as what head is better for ls/vtec's, i'd go for gsr heads. they give u a little more compression. but if u can get a better deal with a b16 or itr or gsr then go for it. the only drawback for older b16 heads is that most of em are old and would cost more money to replace the seals, valves, valvetrain (double check for wear and tear on these old heads just to protect ur investment). just keep in mind that some of these b16 heads are over 10 years old.
my 2 cents.
Old Mar 9, 2002 | 11:39 AM
ATeg92's Avatar
Spent the extra cash and get a C5 head.
Old Mar 9, 2002 | 02:42 PM
project_DC2's Avatar
Default Re: WHAT HEAD IS BETTER FOR LS/VTEC (randyman)
B20/VTEC: so whats the diff. between gsr heads and itr heads! I was thinking of getting the itr head to put on the b20 block instead of the gsr's? Shouldnt itr heads to better than GSR heads....on the b20 block?
Just trying to form some research!
Old Mar 10, 2002 | 12:05 AM
randyman's Avatar
New User
Default Re: WHAT HEAD IS BETTER FOR LS/VTEC (project_DC2)
it depends really on the kind of deal that u get. don't get me wrong, all the vtec heads are excellent candidates for the ls or b20/vtec. but if u want to get more compression the gsr will yield more due to its tighter combustion design -- or something. the b16 and itr heads flow better -- but u'll lose some compression due to it's wider combustion chambers --- or something.
again, if ur going to build the monster right u should contact ur dealer first regarding piston spec so they can give u the right compression ratio when combo'd with the head of ur choice and the block that the piston is going into.
if ur just going to leave everything stock, then try to get the gsr head and some thinner head gasket to scavenge all the compression needed to compensate for the head swap (note: ls and/or b20 pistons have shallow valve reliefs so make sure that u clay check for valve-to-piston clearances before getting really thin head gaskets. milling the head is also a no-no if u want to gain more compression. milling should only be done just the get the head level and straight).
pick ur poison. and that, as they say, is that.
Old Mar 10, 2002 | 01:00 AM
SEIKI's Avatar
Road head is the best!!
Old Mar 10, 2002 | 06:34 AM
743power's Avatar
Default Re: WHAT HEAD IS BETTER FOR LS/VTEC (SEIKI)
The combination of a b18/b20 block and a b18c1 head is going to give you 3/4-1 point higher compression right off the bat compared to a b16 head. This is something to consider if you plan on running a piston like a pr3 or a jdm type r (don't even think about using the ctr piston unless this is a race motor). Sure, everybody looks for that higher compression, but you have to consider how far you want to take it. I say go for the b16/c5 head. You can have more control over your compression ratio, instead of having a daily driven 12.5:1 monster. Besides, the gsr's are more expensive and harder to come by than a b16, so you can use the money you saved on headwork.
Old Mar 10, 2002 | 09:11 AM
ARunto's Avatar
Default Re: WHAT HEAD IS BETTER FOR LS/VTEC (743teg)
I'd go B16A head
-Alan
Old Mar 10, 2002 | 11:13 AM
Leimokei's Avatar
New User
Default Re: WHAT HEAD IS BETTER FOR LS/VTEC (ARunto)
ls/vtec B16a is actually a better choice, first of all. You can find it cheap and their abundant, secondly GSR heads are little more expensive...the difference is small...jeff from importreview.com has a dyno chart...so you can go their site and take a look...
Old Mar 10, 2002 | 11:16 AM
Mr. Softee's Avatar
Default Re: WHAT HEAD IS BETTER FOR LS/VTEC (Leimokei)
gsr head.
Old Mar 11, 2002 | 11:30 AM
OneThirtyEight's Avatar
Default Re: WHAT HEAD IS BETTER FOR LS/VTEC (94goldjungsr)
get the SI head, with ITR cams. I think inlinepro sells a b16a complete already drilled, tapped and all oil lines for like 850. its kinda high, but if you want something already all set up for you there are places that sell them.
Old Mar 11, 2002 | 12:59 PM
Muglit's Avatar
New User
How do you figure?
The combustion chamber sizes are not that different 41.6(gsr) vs 42.7(b16), I believe.
Go to this link: http://www.bojangz.com/calculator/
Old Mar 11, 2002 | 06:08 PM
743power's Avatar
Default Re: WHAT HEAD IS BETTER FOR LS/VTEC (Muglit)
wow, I couldn't be more wrong. . .
looks like there's a .3-.5 difference.
Old Mar 11, 2002 | 10:43 PM
Muglit's Avatar
New User
with stock ls pistons and only switching between b16 and gsr head it is ~.2 difference.
Johnoolo
Jul 7, 2013 01:34 PM
96lsintegra
Mar 20, 2006 09:33 AM
metal-x
Oct 22, 2002 04:13 AM
z crx z vtec z
Mar 8, 2002 09:05 PM
