jrsc fmu
NO... the JR FMU is just fine. i'm using it on a GSR motor with stock boost (6psi).
if it was too low, JR wouldn't include it with their kit. if you get a higher one, like 12:1, you'll just run that much richer while in boost.
you can still use it with turbo. all depends on how much boost, injectors, fuel pump you will be using.
i used to use a 10:1 with my ls turbo on 10lbs of boost and rc 310cc injectors.
