i need help and search is down, distributor problem!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 29, 2005 | 08:05 PM
xtreme-customz's Avatar
Default i need help and search is down, distributor problem!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i need the pin out to convert my hatch to a obd1 distributor!!!!!!!!!!!
Old Oct 30, 2005 | 06:54 AM
Default Re: i need help and search is down, distributor problem!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (xtreme-c
i need help and search is down, distributor problem!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (xtreme-customz)
Old Oct 30, 2005 | 07:08 AM
EJ1 wilcox's Avatar
Haha...
That's four of us going through this in the same weekend!!!
https://honda-tech.com/zerothread?id=1418266
https://honda-tech.com/zerothread?id=1417645
https://honda-tech.com/zerothread?id=1417709
Depin the OBD0 plug wire by wire and insert each wire into the matching color OBD1 plug location.
When you get to the two white wires on the OBD0 plug, put the thicker white wire that's outside the loom (see one of the other threads I posted) in the space where the OBD1 yellow/green wire is.
Hope this helps!!
CivicBlacksheep
Jun 5, 2025 12:28 PM
elmalouno
Jun 2, 2010 11:22 PM
efjones9
Jan 15, 2009 10:17 PM
em2ssm02
Jul 24, 2007 08:27 PM
