RMF Drag/Step Header, Rocket M24X Cams, PLX M-300, 89mm Crank, RS Machines Block
Old Oct 29, 2005 | 07:09 PM
asubennett's Avatar
Default RMF Drag/Step Header, Rocket M24X Cams, PLX M-300, 89mm Crank, RS Machines Block
RMF Drag/ Step Header
1 7/8 inch primaries steps into 2 inch secondaries
True RMF Made Merge Collector
Mega Phone into Three Inch Flange
Two O2 Bungs for Wide Band
$650 Shipped Firm
Rocket Motorsports M24X Intake and Exhasut B-Series Cams
Specs:
12.7mm Lift
297 Degrees Duration
$650 Shipped------ NEW PRICE $600 SHIPPED
PLX M-300 Wide Band
$275 Shipped-----------------NEW PRICE $240 SHIPPED
89 MM LS Crank out of a B18B Motor with 90,000 miles
$60
RS Machines 86mm Block
Currently at 86mm Bore, Three Cylinders are Perfect with 86mm 7CC Dome CP Pistons installed
A Valve dropped on on cylinder and ruined the piston. Made a couple of slight imperfections on that cylinder. If it were me I would bore to 86.5mm and continue. You could also buy one replacement piston from CP for $135 and install and go.
I will sell this twop different ways.
1) As is without pistons for $600
2) As is with pistons for $700
3) Fresh bore and hone to 86.5mm for $750
This motor made 235+whp at 86mm bore imagine 86.5mm bore. :-)
I use Indian Head Gasket Sealer with this motor so that is what you are seeing on the deck of the block. It is real sticky stuff. This pic is literally me just pulling the head and popping out the bad piston.
Modified by asubennett at 10:29 PM 10/30/2005
Old Oct 29, 2005 | 08:14 PM
asubennett's Avatar
Default Re: RMF Drag/Step Header, Rocket M24X Cams, PLX M-300, 89mm Crank, RS Machines Block (asubennett)
Header SOLD< SOLD
Old Oct 30, 2005 | 08:37 AM
asubennett's Avatar
Back up top
Old Oct 30, 2005 | 04:17 PM
asubennett's Avatar
Back up Top. PM for special prices. Need sold.
Old Oct 31, 2005 | 12:31 PM
asubennett's Avatar
Back Up Top
Old Nov 1, 2005 | 03:12 PM
asubennett's Avatar
Back up Top
Old Nov 2, 2005 | 04:19 PM
whiskaz's Avatar
pm'd
Old Nov 2, 2005 | 10:38 PM
asubennett's Avatar
Default Re: RMF Drag/Step Header, Rocket M24X Cams, PLX M-300, 89mm Crank, RS Machines Block (whiskaz)
Crank is fine. No chips or scratches or out of roundness. Just needs a micropolish.
Old Nov 3, 2005 | 09:13 PM
asubennett's Avatar
Back Up Top
Infinite Auto
Jan 25, 2004 05:55 PM
