B20z Questions/Clutch Bolts Qs
Old Oct 29, 2005 | 06:40 PM
Qboi86's Avatar
Default B20z Questions/Clutch Bolts Qs
i'm in the process of putting my motor together..
i have an exedy pressure plate, there's like 9 bolts to it, but i only have 5 cuz i broke 1 when taking it out from a D-series motor, but i still need a few more...now is it safe for me to put that 5 and use like 4 other bolt? is the pressure plate bolt design for a specific reason? or is it just to hold the assembly together? what's the pros. and cons.
and how can you make the B20z fuel rail fit in an integra intake manifold...cuz i try it and the fuel rail bolt doesn't line up right?
Old Oct 30, 2005 | 04:46 AM
Blaze45's Avatar
Brrraaaap!
Default Re: B20z Questions/Clutch Bolts Qs (Qboi86)
The B20 is mostly mated with an auto tranny, so your going to need some 5spd flywheel bolts that are a few threads longer. I dunno if D series is the same or not, Id assume that they are. Id make sure that you have all the bolts that need to be in there cause the flywheel spinds very fast and if its un balanced it could cause some issues with your motor or cause premature wear on something. And besides, once you have the tranny on, you dont want to have to take it off just to put that one bolt back in. As for the fuel rail, use the integra one, that year that corresponds with whatever IM your using. The B20 one prolly wont fit on an LS if you have the giraffe style IM.
Blaze
integra3586
Feb 20, 2006 10:07 PM
88_T-Rex
Jul 11, 2005 10:20 PM
jdmintegra1994
Nov 21, 2003 10:15 AM
IS3Fifty
Apr 8, 2003 09:23 PM
crxgurlllll
11
Dec 10, 2002 09:23 AM
