Spun Bearing again in 3
Old Oct 29, 2005 | 05:10 PM
cltitus's Avatar
Default Spun Bearing again in 3
Well late august i spun cylinder 3 bearing, mechanic said he micropolished it and rebalanced it well just about a week ago my dad was driving and knocking sound it spun again should the mechanic fix it again for doing a fucked up job the first time witha new crank for free or what action should i take. when i get back tot he states i was going to do a crower 2.2L stroker kit but my dad needs my car running while he is fixing his.
Old Oct 29, 2005 | 06:17 PM
ZygSpeed's Avatar
Default Re: Spun Bearing again in 3 (cltitus)
Thought YOU repaired that yourself, said something about using all yellow bearings, etc.
My bad, must have been "planetstereo" ...
Modified by zygspeed at 2:08 PM 10/30/2005
Old Oct 29, 2005 | 06:22 PM
RPRacing's Avatar
Default Re: Spun Bearing again in 3 (zygspeed)
If he only micropolished the crank to fix it after a bearing had spun on you, than he is at fault. I've never seen a bearing spin on a honda and not expletive the crank up. Hell, i've seen bearings not spin, but get down thick into copper and expletive the crank up. I would get him to fix it. Although i have to give him (the mechanic) the benefit of the doubt that you misunderstood what all he did to the motor to fix it. If possible, get some money from that mechanic and take the motor to another machine shop to get a whole rebuild done.
Old Oct 29, 2005 | 07:18 PM
uNF$@#!'s Avatar
Default Re: Spun Bearing again in 3 (RPRacing)
this whole "expletive" crap is so friggin
Old Oct 29, 2005 | 08:49 PM
Haleiwa-Brando's Avatar
Default Re: Spun Bearing again in 3 (255.255.255.255)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 255.255.255.255 &raquo;</TD></TR><TR><TD CLASS="quote">this whole "expletive" crap is so friggin </TD></TR></TABLE>
God tell me about it. I hate being censored. Don't remember that being in the terms when I agreed with becoming a member here either. PC = ******* stupid. Heaven forbid someone get's their poor little feelings hurt.
On topic....if you rebuild your engine with that stroker kit are you going to use a different color from Honda to have tighter tolerences? Or are you going with an aftermarket bearing kit?
Old Oct 30, 2005 | 09:42 AM
cltitus's Avatar
im going with aftermarket bearing kit, looks like my cars sitting under a tent for 3 months while i save up my money.
Old Oct 30, 2005 | 09:58 AM
migs's Avatar
Default Re: (cltitus)
Main caps switched?
Old Oct 30, 2005 | 10:23 AM
cltitus's Avatar
pretty much every baring o thi hopefully doent haappen again jut need this bitch running so i can drive around to gt my dart engine start being built down car is my only transportation
dallasyoung
Nov 2, 2011 04:53 PM
xxmastermindxx
Jun 14, 2007 03:05 PM
ls19integra95
Feb 20, 2007 03:42 PM
