obd0->obd1 dizzy wiring...in a jam and search engine is down
Old Oct 29, 2005 | 04:43 PM
PA MATT's Avatar
Default obd0->obd1 dizzy wiring...in a jam and search engine is down
Im wiring up my obd1 dizzy plugs on the obd0 wire harness. I've got the smaller plug done. On the larger plug, I've mated the yel/blu, white/blu, green/blu, orange, orange/blu. Now on the plug, I still have a yellow/green wire and a plain white wire. On the harness, I'm left with only 2 white wires. Anybody have any idea which goes where? I was under the assumption they were all color coded. TIA
Old Oct 29, 2005 | 04:57 PM
Rywire's Avatar
Default Re: obd0->obd1 dizzy wiring...in a jam and search engine is down (PA MATT)
thick white to yel/grn.. thats the ignitor wire. If you have a hasport ecu jumper, or a dizzy king (or aftermarket) dizzy the wiring will be incorrect...
Old Oct 29, 2005 | 05:02 PM
EJ1 wilcox's Avatar
This is the EXACT same question I ran into this afternoon!! LoL...
https://honda-tech.com/zerothread?id=1417645
I did the same thing. I depinned the OBD0 dizzy plug wire by wire and matched the colors up with the same colors on the OBD1 dizzy plug.
Then I discovered that there are two white wires on the OBD0 plug, and one white wire on the OBD1 plug (and a yellow/green wire left over). I need to figure out if I just plug one of the white wires from the OBD0 plug into one of the white wires in the OBD1 plug and the other white OBD0 wire to the yellow/green wire.
And IF that is the case. Which OBD0 white wire to I hook to the OBD1 white wire, and which do I hook to the yellow/green??
I looked all over for a pinout for the OBD1 dizzy but couldn't find one. I also spent almost two hours searching through all of the DPFI to MPFI tutorials and couldn't find the answer to this question.
Bump for an answer!!!
Old Oct 29, 2005 | 05:04 PM
EJ1 wilcox's Avatar
Default Re: obd0->obd1 dizzy wiring...in a jam and search engine is down (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">thick white to yel/grn.. thats the ignitor wire. If you have a hasport ecu jumper, or a dizzy king (or aftermarket) dizzy the wiring will be incorrect...</TD></TR></TABLE>
So one of the white wires from the OBD0 plug is thicker than the other white wire?
And the thicker one goes with the OBD1 yellow/green? Then the thinner wire goes with the OBD1 white wire?
Old Oct 29, 2005 | 05:06 PM
Rywire's Avatar
Default Re: obd0->obd1 dizzy wiring...in a jam and search engine is down (EJ1 wilcox)
Yes, its the wire that all alone, pull back the tape, its the only wire not in the covering... Easy as that
Old Oct 29, 2005 | 05:16 PM
PA MATT's Avatar
sorry, running on very little sleep...lol
the one all alone goes to the white wire or the yellow/green?
Old Oct 29, 2005 | 09:02 PM
EJ1 wilcox's Avatar
Here's what he means, I took a picture of my wiring this evening.
This picture shows the loom peeled back a bit, you can see that one of the white wires is thicker than the other, and is outside the loom where the other dizzy wires are shielded.
That thicker white wire is the one that gets connected to the yellow/green wire.
Thanks for the help by the way!!
Old Oct 29, 2005 | 10:41 PM
Rywire's Avatar
NP man, good luck, and nice pic
Ryan
CRXCRAZYD16Y8
15
Feb 23, 2006 11:32 AM
Dancing is Forbidden
Dec 1, 2005 09:14 AM
rasta420
Jun 21, 2005 07:41 PM
BoRiCuA
18
Jun 21, 2004 12:15 PM
