passenger side window does not roll down, Need suggestions, pls
Old Oct 29, 2005 | 04:34 PM
2000civicsi's Avatar
Default passenger side window does not roll down, Need suggestions, pls
Yr: 2000
Model: Civic SI
Power window suddenly does not work today, was working fine yesterday.
Driver side window had no problem at all, only passenger side
i don't hear any motor spinning sound
how can i fix this, where to start from
fuse? (where)
loose cable? (how to check)
motor?
thanks in advance
Modified by 2000civicsi at 6:09 PM 10/29/2005
Old Oct 29, 2005 | 04:41 PM
spoonfedcrx's Avatar
Default Re: passenger side window does not roll down, Need suggestions, pls (2000civicsi)
first check fuses, then pull off door panel and see if ur getting power to the window motor, if ur gettign power then u need a motor. if ur not getting power then u have a switch or a wire problem.
does the window work/not work from the master switch/pass switch?
Old Oct 29, 2005 | 04:43 PM
Default Re: passenger side window does not roll down, Need suggestions, pls (spoonfedcrx)
no
92-CivicLX
Sep 23, 2013 07:46 AM
lucfleclerc
Apr 25, 2013 01:55 PM
bighoss77
Aug 16, 2012 08:44 PM
DrGrEeNtHuMb
Mar 12, 2009 02:51 PM
AzntstyleZ
Sep 27, 2004 06:45 PM
