Settings for Stainless Steel? Thermal Arc 185
Old Oct 29, 2005 | 03:34 PM
Pikachu's Avatar
Default Settings for Stainless Steel? Thermal Arc 185
Hey guys. I went to a shop and they've been around for many years and today for the first time I used my Thermal Arc. I however wasn't really able to put down a really good bead. Now I think this is due to a few different factors.
Gas that was used is not straight argon but a trimix of argon, helium, and Co2. They said this was best for stainless. Is this true?
I set the flow to 25cfm as recommended.
Out of curiosity, what gas is used for mild steel? Will the trimix work as well?
I want to do some muffler work as well. Any advice on what settings to use?
Thanks guys.
Old Oct 29, 2005 | 05:02 PM
k24em2's Avatar
Default Re: Settings for Stainless Steel? Thermal Arc 185 (Pikachu)
You need pure argon for TIG. It looks like they sold you the trimix as they thought you were using a MIG welder. Pure argon is used for most tig applications, except in some aluminum cases you can use helium or an argon/helium mix.
Old Oct 29, 2005 | 07:56 PM
Pikachu's Avatar
Ohhh... Crap gotta bring it back. I'll bring it back Wednesday. Damn tank weighs a ton.
Can I do mild and stainless with straight argon? Thanks.
Old Oct 29, 2005 | 07:59 PM
stirnice's Avatar
Default Re: (Pikachu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pikachu &raquo;</TD></TR><TR><TD CLASS="quote">Ohhh... Crap gotta bring it back. I'll bring it back Wednesday. Damn tank weighs a ton.
Can I do mild and stainless with straight argon? Thanks. </TD></TR></TABLE>
Run argon with your TIG and the trimix with your MIG. Argon+TIG should weld just about anything you need to.
Old Oct 29, 2005 | 08:04 PM
Pikachu's Avatar
Problem is that I don't have a mig. Just a tig in my garage. The tank is a rental. I can just bring it back.
Old Oct 30, 2005 | 06:45 PM
Pikachu's Avatar
What about mild steel?
Old Oct 30, 2005 | 07:08 PM
k24em2's Avatar
Pure argon works for just about everything with TIG.
Old Oct 31, 2005 | 04:38 PM
Bjorn's Avatar
Default Re: (k24em2)
that's strange, I've heard tri-mix is better for SS tig than argon. Any reason why trimix wouldn't shield hand fed filler versus machine fed?
Old Nov 1, 2005 | 08:12 PM
Pikachu's Avatar
I changed it to argon and it's a bit better.
andyvaj
Welding / Fabrication
Sep 2, 2007 05:55 PM
Flashmn
Oct 31, 2005 03:44 PM
yellowturbo
11
Mar 12, 2005 10:00 PM
ivsihi
Feb 14, 2005 07:52 AM
ExploitedRacing-HR
Dec 16, 2004 03:17 AM
