need to get it running
Old Oct 29, 2005 | 12:24 PM
turbob16ef's Avatar
From: if you build it they will come, the bottom carolina, duh
Default need to get it running
i just bought this 90 crx si for 300 with no rust. the only problem witth it is that the people said that the head is cracked and the timing belt has jumped a couple teeth. but i think it is just a blown head gasket and the bad timing. how do you tell the difference between the two. i know checking the comp. but would it be the same low comp. My ? is how to tell the difference between them two.
thanks in advance
Old Oct 29, 2005 | 01:49 PM
EF8IGHT's Avatar
Default Re: need to get it running (turbob16EF)
pull the head off and check
slowcrx954
Jan 7, 2008 04:20 PM
petarr
Apr 7, 2006 10:11 PM
88hatchef
Nov 21, 2005 04:46 AM
Black97GSX
Nov 2, 2004 10:34 PM
civicguy
Jan 23, 2002 06:47 PM
