Will running my AC without the fan hurt anything?
Old Oct 29, 2005 | 09:38 AM
EK k kay's Avatar
Default Will running my AC without the fan hurt anything?
I'm going turbo and don't really want to remove the ac so would removing just the fan hurt anything if I ran without it?
Old Oct 29, 2005 | 09:53 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Will running my AC without the fan hurt anything? (EK k kay)
you will not have the full effect of the ac then, w/o the condensor fan, you will not be cooling the car's cabin nearly as well. we did that to my friends type r and ended up taking it out all together.
Old Oct 29, 2005 | 10:10 AM
mx621's Avatar
Default Re: Will running my AC without the fan hurt anything? (boostedcivicsir)
as a hvac tech, it will be ok when moving, but when you slow down or stop, the compressor will trip out on high pressure, im sure it will work until the compressor craps out, which runing a head pressure of 450-500psi when u stop, the compressor wont last long. they sell manifolds that will work with a/c.
Old Oct 29, 2005 | 10:45 AM
dinko's Avatar
Default Re: Will running my AC without the fan hurt anything? (mx621)
quit being lazy. just remove the ****! haha.
Old Oct 29, 2005 | 10:47 AM
EK k kay's Avatar
I probably wouldn't be using AC anytime soon since it's pretty cold around here now (40-50F). I'll probably look for a slimline fan if I really need AC.
Cuda70's Avatar
If you are talking about removing the fan, you can...
You will need an aftermarket electric fan and mount it to the front of the condenser. Remember to make sure you have the polarity switched so the fan blows air through the condenser and not away from it.
That will give you a couple of extra inches to play with between the turbo and your condenser.
Old Oct 29, 2005 | 10:48 AM
EK k kay's Avatar
Default Re: Will running my AC without the fan hurt anything? (Cuda70)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cuda70 &raquo;</TD></TR><TR><TD CLASS="quote">If you are talking about removing the fan, you can...
I also heard about people taking the stock fan and putting it on the front of the condensor and doing the same thing you're talking about. Would this get in the way of a small front mount?
knotcher
Jun 29, 2015 10:34 AM
geribair
Jun 7, 2014 11:18 AM
duyfash0
Oct 8, 2008 06:46 PM
playahwitgame
Jun 20, 2006 04:40 PM
