ecu chipping
Old Oct 29, 2005 | 09:33 AM
2DoorBandit's Avatar
Default ecu chipping
i was planning on chipping my ecu but i just want to know how hard it is. and also what do i get i was looking at a website that sells chippoing kits and it said something about select an Eprom here is the website https://honda-tech.com/zero...id=15 is that kit good
my car is a 93 civic ex OBD1
Old Oct 29, 2005 | 12:40 PM
NJIN BUILDR's Avatar
Default Re: ecu chipping (2DoorBandit)
The real question is have you desoldered and soldered circuit boards before.It's easy to make yourself a nightmare with a marginal soldering job.There are plenty of good people willing to chip it for short money.If your just doing one or two for yourself its cheaper to have someone else do it.
Glenn
Old Oct 29, 2005 | 07:46 PM
Default Re: ecu chipping (NJIN BUILDR)
i went to school for electronics so i solder thin for 4 years. i just dont know where to look for shops that do thing like that
Old Oct 30, 2005 | 01:03 AM
No_Fear's Avatar
http://www.pgmfi.org/
Old Oct 30, 2005 | 01:35 AM
2k.civic.si's Avatar
Default Re: (No_Fear)
"said something about select an Eprom " and you were in electronics for how long?
Old Oct 30, 2005 | 04:39 AM
rainforest's Avatar
Default Re: (2k.civic.si)
you will need a 29c256 eprom chip. Also a eprom chip is a erasable read only memory chip. wich means it will retain knowlage when there is no power to it. But can be erased by exposeure to ultra violet light.
Old Oct 30, 2005 | 06:55 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si &raquo;</TD></TR><TR><TD CLASS="quote">"said something about select an Eprom " and you were in electronics for how long?</TD></TR></TABLE>
i dident really pay attention all the time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainforest &raquo;</TD></TR><TR><TD CLASS="quote">you will need a 29c256 eprom chip. Also a eprom chip is a erasable read only memory chip. wich means it will retain knowlage when there is no power to it. But can be erased by exposeure to ultra violet light.</TD></TR></TABLE> thanks for the advice
i posted the wrong website before does this kit look legit http://www.xenocron.com/produc...gkits
Old Oct 30, 2005 | 01:43 PM
SVOboy's Avatar
Default Re: (rainforest)
You don't need a 29c256, the atmels are so hard to find these days, and also more expensive, I use 27c512 because they're less than a buck so I got 5 of them plus some other crap shipped for the cost of a 27c256 before shipping. I just use the 27c512 when I chip stuff, cuz it only takes a while to erase with a proper eraser. The xenocron kit is legit, I'd get it from moates.net though since it's cheaper.
Old Oct 30, 2005 | 02:57 PM
the 29c256 is electronicly erasable...the 27c256 is the one with a quartz window on top for uv erase...i get bags of the 27c256's for dirt cheap...the 29c256's go for about 6 bucks a pop
Old Oct 30, 2005 | 02:59 PM
SVOboy's Avatar
Yep, gotta love the cheap method. I always just have a bunch so I can write them and leave the others erasing and I'll never need to wait.
Old Oct 30, 2005 | 03:13 PM
D15bJDM's Avatar
Hey this Drew from spartanburg SC. Do you know any thing about a DOHC ecu
Old Oct 30, 2005 | 03:18 PM
D15bJDM's Avatar
Default Re: (D15bJDM)
Hey Civic-Si do you know any thing about DOHC ecu on SOHC engine.
Old Oct 30, 2005 | 03:19 PM
V8MeatHead's Avatar
From: Holley 4053, carb 406 stroker anal Luber, Fag
Default Re: (2DoorBandit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2DoorBandit &raquo;</TD></TR><TR><TD CLASS="quote">i dident really pay attention all the time
but for 4 years? What kind of school did you go to!?
basiceg6
Nov 27, 2009 09:45 AM
juanintec
May 22, 2008 09:53 AM
teamredline9k
Jun 21, 2006 04:38 PM
Ryu
Oct 30, 2002 09:37 AM
volkracing99
Jan 17, 2002 01:06 PM
