Slightly Squeeky Suspension
Old Mar 7, 2002 | 09:18 PM
EF'n Fast's Avatar
Default Slightly Squeeky Suspension
I just had my suspension installed, and sometimes there's a slight squeeking sound coming from what sounds like the front driver side suspension. It sounds like an old matress. Is this a big deal?
Thanks.
Ed
Old Mar 7, 2002 | 09:23 PM
bryant's Avatar
Default Re: Slightly Squeeky Suspension (EF'n Fast)
its no big deal, just put some WD-40 on there and you should be good to go.
Old Mar 8, 2002 | 03:02 AM
Xstatic's Avatar
Default Re: Slightly Squeeky Suspension (CR-X)
did you get polyurathane bushings installed???if so that is why it is squeaking, it'll be a regular, prolly annual day in the garage re-greasing them in order to keep them from squeaking....
if not, then well maybe the spring isn't sitting in the perch right, but i would not use WD-40 it qwill eat at the rubber, instead use a silicone based lubricant, they are rubber-freindly.....
Old Mar 8, 2002 | 06:47 AM
bryant's Avatar
Default Re: Slightly Squeeky Suspension (Xstatic)
Good call, i dont know what i was thinking
stocktonhidlude
Nov 5, 2006 06:42 PM
lude-tec
Suspension & Brakes
Mar 31, 2006 12:49 PM
