need some help with 5th gen
anyone got any pictures of a control arm in the front or would know what i wouls need to fix my wheel. the wheel does not sit straight down. looks like camber wear but its more then that because the owner before said he hit a curb. anyone have a idea on what needs to be replace other then the tire? it is lowered with tokico springs and shocks the left tire is perfectly straight and 0 camber wear
check that area if anything is bent out of shape...but from what you're telling me...i would look at the: upper control arm, damper fork, radius rod, lower control arm, stabilizer bar (sway bar), all rubber bushings, and axles.
well i took my car to get a alighment and they said that my lower control arm is bad and which of course i could understand but there is more issue where they say the sub frame is bent... how much you think that would run?
tonysaur
Dec 25, 2005 02:05 AM
