what kind of oil for a lsd tranny?
this is my first car with a lsd it is a y1 cable and it could use a oil change. i was reading up on some oils and it said not to use just regular oil like i do in my teg with no lsd because it will loose some of it's effectiveness. so what are my options?
I would run genuine honda oil!! Go to your local auto place and see if they sell Lucas for the transmission. I would add a little bit! Dont add the recommended amount just add a little to your oil. Some LSD require special oil but I dont think that it really matters. I have a JDM y1 and I use Honda Oil with a little bit of lucas to stabalize the oil. GOOD LUCK!
Y1?
clutch pack LSD?
i would use this
Amsoil MTF (or GM/Pennzoil Syncromesh, or GM Syncromesh FM)
Lubegard LSD additive
i used Syncromesh + LG LSD additive in my Y1 LSD
= rules .. no chatter
clutch pack LSD?
i would use this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexdog69 »</TD></TR><TR><TD CLASS="quote">Y1?
clutch pack LSD?
i would use this
whats the paste looking thing for? also do you just mix it with the oil while filling the tranny oil?
clutch pack LSD?
i would use this
Use Amsoil in your prefered grade
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks_jdmstyle_ef9 »</TD></TR><TR><TD CLASS="quote">I would run genuine honda oil!!</TD></TR></TABLE>
Made by exxon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks_jdmstyle_ef9 »</TD></TR><TR><TD CLASS="quote"> I would run genuine honda oil!! Go to your local auto place and see if they sell Lucas for the transmission. I would add a little bit! </TD></TR></TABLE>
Don't use that Junk!!!!!!!
http://www.bobistheoilguy.com/...s.htm
Made by exxon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18_crx »</TD></TR><TR><TD CLASS="quote">gm syncromesh!
i have always known about amsoil but i didnt know they made stuff for lsd's. if i buy the amsoil mtf does it come with the adative for the lsd?
I have a clutch type lsd. Be very careful of what kind of lsd you have. I got the lsd from a friend of mine and I just swaped in the entire differential not knowing if it was clutch type or helical.
So I was running like 130 weight gear oil and the tranny was screaming. Well I finally broke 3 damn axles and then I figured out that I needed to run a additive. I've tried the GM additive and the Ford additive and they both work great with thick gear oil.
