Suspension & Brakes Theory, alignment, spring rates....
No dust boot on shocks bad
Old Oct 28, 2005 | 11:41 PM
shyboi4u's Avatar
Default No dust boot on shocks bad
when you put coilovers on. you have to take out the dust boot because its to big to fit in the coilovers. so is it bad not to have the dust boot on? i'm not talking bout full coilovers.
Old Oct 29, 2005 | 09:55 AM
shyboi4u's Avatar
Default Re: No dust boot on shocks bad (shyboi4u)
bump
Old Oct 29, 2005 | 09:01 PM
shyboi4u's Avatar
no help for me, huh? figures!
Old Oct 29, 2005 | 09:59 PM
GZERO's Avatar
I can give you my opinion.
A dust boot will make your shocks last longer. But it really all depends on where you drive.
My advice, get one. It's cheap, it's not ugly (even tough you can't see it), and it doesn't hurts anything, if it does something, it will be to keep dust away from your shock seals.
Good luck
Old Oct 29, 2005 | 10:03 PM
shyboi4u's Avatar
Default Re: No dust boot on shocks bad (GZERO)
thanks alot for your opinion, mang. really helps.
Old Oct 30, 2005 | 01:55 PM
russdoe's Avatar
On my ITR I have Koni shocks and Ground Control adjustable springs. For the front I just cut the dust boots in half so they are shorter. For the rear I had to go without. Since I travel on muddy / gravely roads, I thought dirt could get between by shock and spring sleeve. So I cut a piece of motorcycle innertube about 3" high and zip tied it to the bumpstop and top of the spring sleeve to cover the opening on the sleeve. It might not be necessary for city driving tho.
Old Oct 30, 2005 | 03:33 PM
shyboi4u's Avatar
Default Re: No dust boot on shocks bad (russdoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by russdoe &raquo;</TD></TR><TR><TD CLASS="quote">On my ITR I have Koni shocks and Ground Control adjustable springs. For the front I just cut the dust boots in half so they are shorter. For the rear I had to go without. Since I travel on muddy / gravely roads, I thought dirt could get between by shock and spring sleeve. So I cut a piece of motorcycle innertube about 3" high and zip tied it to the bumpstop and top of the spring sleeve to cover the opening on the sleeve. It might not be necessary for city driving tho.</TD></TR></TABLE>
the dust boot actually fit in the coilover? i thought it was to big to fit in the there? or was it to long. can't remember.
Old Oct 31, 2005 | 09:22 AM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shyboi4u &raquo;</TD></TR><TR><TD CLASS="quote">
the dust boot actually fit in the coilover? i thought it was to big to fit in the there? or was it to long. can't remember.</TD></TR></TABLE>
you can do this if you want dust boots
https://honda-tech.com/zerothread?id=917766
Old Oct 31, 2005 | 01:27 PM
dogbiscuit's Avatar
i have seen ATV's that have a thick fabric type shock cover that slips over the spring itself and covers the whole assembly.
has anybody ever used something like this on their car?
sorry for slight thread jacking
here's what i am talking about
Modified by dogbiscuit at 2:38 PM 10/31/2005
Old Oct 31, 2005 | 07:45 PM
shyboi4u's Avatar
Default Re: No dust boot on shocks bad (nonsense)
thanks.
Kowalski
Suspension & Brakes
Mar 27, 2005 03:24 PM
H22dave
Jan 6, 2004 05:40 AM
jspec-integ Ls
Sep 10, 2003 10:54 AM
RJx
Aug 19, 2003 10:21 PM
-iLLuZioN-B18C1
Aug 11, 2003 02:42 PM
