quik question...On wiring plz answer.
Old Oct 28, 2005 | 09:31 PM
ivanson's Avatar
Default quik question...On wiring plz answer.
Im gonna help my friend swap his motor..
his gonna swap a d16z6 to a 89 crx dx..
He came up on some SI wiring harness...
what do i have to do to the wiring shock towers
and to the ecu...thank you
Old Oct 28, 2005 | 09:41 PM
tyro's Avatar
Default Re: quik question...On wiring plz answer. (ivanson)
You're going to need to do the MPFI swap.
You will need connnectors off the Si harness, that's it. Injector clips, Injector resistor box and it's connector and plug if you plan to use OBD0 injectors, Dizzy connector, TPS will need to be extended, etc etc etc
Do a search for MPFI, a couple of the posts have 4 links to informative sites...
I see search is down, here's a link for fourthgenhatch to get you started:
http://www.gutterslide.com/fou....html
Old Oct 28, 2005 | 10:47 PM
Rywire's Avatar
Default Re: quik question...On wiring plz answer. (tyro)
Yup,you gotta do the dp to mpfi conversion
Old Oct 28, 2005 | 11:51 PM
ivanson's Avatar
Default Re: quik question...On wiring plz answer. (droppedcrxsi)
so from the engine bay its okay rite?
just connect it to shock towers and get a resistor box..?
and from ecu i add more wires?
Old Oct 29, 2005 | 12:00 AM
tyro's Avatar
Basically you use your DX harness to make a new one, the Si harness is not plug-n-play.
Since you really only need a few connectors, I think it wouldn't be worth chopping up a perfectly good Si harness.
Any parts yard should have what you need..
You have to de-pin a couple of the ecu connectors and swap some wires around, it's not that hard, it just takes time and patience.
Old Oct 29, 2005 | 12:37 AM
ivanson's Avatar
so forget the si one and use
the tutorial with the dx one?
and get some extra wires with
pins on the end?
Old Oct 29, 2005 | 08:09 AM
tyro's Avatar
Here are some links for you, all dealing with the MPFI swap:
http://www.angelfire.com/d20/h....html
http://effinmotorworks.com/Effin_MPFI_swap.htm
http://www.geocities.com/teampimports/fuelinj.html
http://www.geocities.com/c_rexboy/mpfi.html
Old Nov 5, 2005 | 06:00 PM
ivanson's Avatar
I followed all the steps to the wiring....
and i still got problems on the car....
with the sohc vtec.....
when i start the car it only revs up to
3k rpm.......and smells like something burning..
like clutch......
can anyone help on this...
i tryed running a pm6 ecu and pg7 ....both does
the same thing..
Jet Black
Aug 24, 2011 06:45 PM
digitally_remastered
Jul 13, 2006 12:04 PM
Racersky
16
Jan 7, 2006 10:50 AM
Dohc 4door Rye
Nov 15, 2005 05:13 PM
Mr. UnderHill
Nov 26, 2003 09:18 AM
