Compression Numbers on a 94 JDM H22A ??
Old Mar 7, 2002 | 07:57 PM
H22ACiViC's Avatar
New User
Default Compression Numbers on a 94 JDM H22A ??
just wondering what i should be at i know consistant across all four cylinders but what kind of numbers should i see thanks
Old Mar 8, 2002 | 03:27 AM
H22ACiViC's Avatar
New User
Default Re: Compression Numbers on a 94 JDM H22A ?? (H22ACiViC)
Nobody knows maybe any websites ??
Old Mar 8, 2002 | 09:21 AM
JinMTVT's Avatar
New User
cr is supposed to be 10.6:1 on thoose
i don't know what that gives in psi
i know that compression is supposed to be pretty much equal in all clinders
+- 10-20psi at max
usually something higher than 160 ..
what are the numbers u got ?
Old Mar 8, 2002 | 08:43 PM
BluLuder's Avatar
Default Re: Compression Numbers on a 94 JDM H22A ?? (JinMTVT)
USDM compressions yeild about 180+ across all 4 cylinders
at .2 lower the Si has 160+ across
Old Mar 9, 2002 | 10:53 AM
H22AMedina's Avatar
Well I have that engine, and the numbers were all at 200-220.
Hope that helps,
Old Mar 9, 2002 | 03:05 PM
Finest's Avatar
Default Re: Compression Numbers on a 94 JDM H22A ?? (H22AMedina)
Was the engine hot? Did you drive it before you did the compression test? Or what other internals do you have? Looks like Type S pistons or something?...
Sproket
May 22, 2006 08:15 PM
GR
Feb 8, 2006 08:39 PM
93H22APrelude
Jul 31, 2005 05:30 PM
chinhead1228
Jun 17, 2003 05:51 PM
