Creaking noise
I have an 03 Si that has started to make a creaking noise. It happens when the motor is under a load, while shifting. If I am at a stop light and I start to go.....it creaks from N-1, 1-2, 2-3 and sometimes 3-4. It sort of resembles a suspension creak, like a bushing noise. It has been doing it for less than a week. The only modifications done to the car are a V2 intake and aluminum shifter bushings.
Has anyone else ever experienced this or know what it could possibly be?
Thanks,
-Rob
Thanks,
-Rob
Motor mount bushing? Just a guess, but if you don't have a torque damper or motor mount insert, your motor is swinging 4-5" on hard upshifts. 4 year old mounts may be getting tired of it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thomas Jenkinson »</TD></TR><TR><TD CLASS="quote">Motor mount bushing? Just a guess, but if you don't have a torque damper or motor mount insert, your motor is swinging 4-5" on hard upshifts. 4 year old mounts may be getting tired of it.</TD></TR></TABLE>
nah, atleast not in my case since it only occurs on slow starts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2004CivicHBSi »</TD></TR><TR><TD CLASS="quote">Steering rack creak.
clutch pedal creak. (mine makes a noise inside the engine bay)
I have have those plus my windshield vibrates a little which drives me nuts. Steering rack and clutch pedal noises are common for EP3s.
well you did say you have aluminum shifter bushings?...could be something wrong with those?...not installed correctly..loose..too tight...i denno just a guess?
GEOz2k7
Oct 30, 2008 11:08 PM
anjapower
Oct 4, 2003 06:35 PM
