Brand New JE Pistons GSR 9.0:1 compression
These pistons are brand new still in the box here's all the specs:
Looking to get $330 for them. They were never used, I sold the car and no longer have use for them. I'm a moderator on HMT, and have many vouches. If you have any questions just ask.
Modified by The Original Whitey at 12:00 PM 10/29/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outkast95LS »</TD></TR><TR><TD CLASS="quote">These should fit an LS no problem right? Shoot me a PM.
The LS has a different bore size
</TD></TR></TABLE>The LS has a different bore size
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outkast95LS »</TD></TR><TR><TD CLASS="quote">I was under the impression that the LS bore was 81mm. Same goes for the B16 and B18C. </TD></TR></TABLE>
I'm pretty sure the ls has an 81.5mm bore. All the specs for these pistons are as pictured so only you can be the judge of weather or not they can work for your specific application.
Just double check to make sure they will work for what you want to use them for, I provided all the info I can to make sure people know exactly what they are getting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outkast95LS »</TD></TR><TR><TD CLASS="quote">do they include wrist pins and rings?
Btw, LS do have a 81mm bore, so they should fit no problem</TD></TR></TABLE>
Its only what comes with the pistons which are the pistons, pins and locks.
The Original Whitey
Mar 4, 2006 02:42 PM
TurboTegB18c
Feb 1, 2006 10:49 AM
Aug 29, 2002 06:30 AM
