Built B18A m/ oversized typr pistons
Old Oct 28, 2005 | 08:26 AM
str8sleepr's Avatar
Default Built B18A w/ oversized type r pistons cheap
I have a B18A block bored 40 over with type r pistons. The block has been decked and hot tanked. The rods have been renotched and have GSR rod bearings. It also has brand new LS main bearings, all new gaskets,brand new Type R oil pump, brand new LS timing belt.BLOCK IS NOT put together and is MISSING MAIN CAPS.(SO YOU WOULD HAVE TO GET SOME MACHINED TO FIT) You would also need a water pump. I spent over $700 on this block and have no use for it. Taking offers!! Willing to part out if no one is intrested in buying all. Work was done by RS.
B18A BLOCK bored 40 over, decked,hot tanked, missing main caps ( would need a new set of main caps and get them align bored. I think its cost like $70-100) - $110
RS MACHINE Over sized Type r pistons - $150
Ls Rods renotched with gsr bearings-$ 140
Gaskets all new top and bottom!- $130
New Ls timing belt- $30
New Type r oil pump-$100
RC Injectors 270cc used (peak and hold)- $120
Gude (Bullfrog) ECU obd-0 - $100
Modified by str8sleepr at 12:44 AM 1/30/2006
Modified by str8sleepr at 12:45 AM 1/30/2006
Old Oct 30, 2005 | 01:54 AM
str8sleepr's Avatar
Default Re: Built B18A w/ oversized typr pistons (str8sleepr)
TTT
Old Oct 30, 2005 | 11:23 PM
str8sleepr's Avatar
midnight bump
Old Nov 1, 2005 | 01:35 PM
str8sleepr's Avatar
up
Old Nov 1, 2005 | 08:46 PM
str8sleepr's Avatar
to the top
Old Nov 7, 2005 | 09:20 AM
str8sleepr's Avatar
Default Re: Built B18A w/ oversized type r pistons (str8sleepr)
mornin bump
Old Nov 7, 2005 | 10:34 AM
str8sleepr's Avatar
noone? taking all offers
Old Nov 8, 2005 | 10:47 AM
str8sleepr's Avatar
Default Re: Built B18A w/ oversized type r pistons cheap (str8sleepr)
TTT
Old Nov 10, 2005 | 08:41 PM
str8sleepr's Avatar
bump
Old Nov 10, 2005 | 09:38 PM
jamescb77's Avatar
if you have this in about 2 more months i will be very interested in it
Old Nov 11, 2005 | 03:07 PM
str8sleepr's Avatar
Default Re: (jamescb77)
yah just check back whenever..
Old Nov 11, 2005 | 06:59 PM
b18vtecboi's Avatar
how much for the rods with the pistons? are they ctr pistons or itr?
Old Nov 12, 2005 | 02:54 AM
str8sleepr's Avatar
Default Re: Built B18A w/ oversized type r pistons cheap (b18vtecboi)
pm'd u
Old Nov 12, 2005 | 10:52 PM
str8sleepr's Avatar
bump
Old Nov 16, 2005 | 05:08 PM
str8sleepr's Avatar
bump
Old Nov 17, 2005 | 11:46 AM
str8sleepr's Avatar
up
Old Nov 17, 2005 | 05:40 PM
str8sleepr's Avatar
Old Nov 19, 2005 | 02:33 PM
str8sleepr's Avatar
anyone
Old Nov 22, 2005 | 12:54 PM
str8sleepr's Avatar
ANYPNE WANT THIS ISH? TAKING OFFERS!!!
Old Nov 22, 2005 | 06:55 PM
str8sleepr's Avatar
bump
Old Nov 25, 2005 | 01:58 AM
str8sleepr's Avatar
ttt
Old Nov 28, 2005 | 10:52 AM
str8sleepr's Avatar
bump
Old Nov 29, 2005 | 09:56 AM
str8sleepr's Avatar
Old Nov 30, 2005 | 02:15 PM
str8sleepr's Avatar
ttt
Old Dec 1, 2005 | 04:27 PM
str8sleepr's Avatar
