Mechanical or electronic oil pressure guage????
Old Oct 27, 2005 | 10:25 PM
eg:R's Avatar
Default Mechanical or electronic oil pressure guage????
looking to purchase a oil pressure guage. which is better-mechanical or electrical?? which brand is better or it does not matter??
Old Oct 27, 2005 | 10:51 PM
sweet_machinery's Avatar
Default Re: Mechanical or electronic oil pressure guage???? (eg:R)
Typical mechanical gauges have 270 degrees of needle sweep. Nice. But they also mean you have hot, pressurized oil being pumped from the engine into the gauge it self, and thus into the passenger compartment. I've personally never been comfortable with that.
Typical electrical gauges have 90 degrees of needle sweep. So it's only a small range of motion for 0-120 PSI of pressure. Almost not worth using.
Then there are the electronic gauges... 270 degrees of sweep and they use a remote mounted pressure transducer and send a resistance or digital signal to a processor in the gauge. All the precision of a mechanical, safety of an electric. $250 please.
Old Oct 27, 2005 | 11:22 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Mechanical or electronic oil pressure guage???? (sweet_machinery)
Yea... expensive, but I would definatly go with electronic. I have seen many oil leaks from people running mechanical gauges into the cabin of the car.
Old Oct 28, 2005 | 05:55 AM
mmuller's Avatar
Mad Scientist
Default Re: Mechanical or electronic oil pressure guage???? (JDM_Ej)
if done right, there is no problems related with using a mech gauge.
just route the line right.
Old Oct 28, 2005 | 06:24 AM
RACEPAK's Avatar
Default Re: Mechanical or electronic oil pressure guage???? (mmuller)
electronic
Old Oct 28, 2005 | 02:13 PM
ALLMOTOR18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">if done right, there is no problems related with using a mech gauge.
just route the line right.</TD></TR></TABLE>
I used steel braided lines and havent had any problems at all..
Old Oct 28, 2005 | 02:44 PM
Flashmn's Avatar
Default Re: Mechanical or electronic oil pressure guage???? (ALLMOTOR18)
Used a mechanical gauge since 2001... I use a copper hard line so that its looped on both ends so that vibration wont break it.
Old Oct 28, 2005 | 06:57 PM
eg:R's Avatar
what brand is good??
Old Oct 29, 2005 | 01:17 AM
Flashmn's Avatar
Default Re: (eg:R)
I've used Autometer sport comp series.
jetspeedz
Sep 13, 2009 06:40 AM
stdefhatch
Mar 20, 2006 03:18 PM
kid-crx
Oct 6, 2005 09:22 PM
DV98CVC
Feb 17, 2003 08:47 PM
