Big brakes + 15" wheels......Help?
Old Oct 27, 2005 | 03:29 PM
80884's Avatar
Default Big brakes + 15" wheels......Help?
Ok here is my situation. I have a 00 civic si. I have the aem rotor upgrade kit, larger rotors, stock calipers. The kit says I need to run at least a 16" wheel. No problem, the car clears 17" and 18" fine. I tried to fit up a stock 00 si wheel just to see how bad they won't clear. That aren't close to fitting. Well here is the dilema. I will be getting the car ready this winter to be running at the track in the spring. I will need slicks on the car. I'd like to be able to keep the brakes and run a 15" wheel so I can run a 26x10-15 slick. If not I will ditch the brakes and run maybe a 13" wheel. I'll worry about that later. Here is my question....if companies make 13" wheels to fit over gsr brakes, is there anyone that would make a drag racing wheel 15" that would clear my brakes?
I know, I know, just get rid of the brakes. Look in my sig, they are forsale. I'm trying to avoid having to swap the brakes everytime i go to the track. Any info?
Old Oct 27, 2005 | 03:41 PM
HapaHaole's Avatar
Default Re: Big brakes + 15" wheels......Help? (80884)
your best bet is any 15" wheel that is fully forged, but good luck with your search.
Old Oct 27, 2005 | 04:02 PM
80884's Avatar
Default Re: Big brakes + 15" wheels......Help? (HapaHaole)
Yea, I am just not sure if any 15" wheel will fit. I'd like to sell the brakes and run stock rotor size smaller wheel. It would be the easiest way. But i can't do that till soemone buys the brakes (new). The search goes on....
Old Oct 28, 2005 | 07:58 PM
EtherGhost's Avatar
Team Dynamics Pro-Race 1 15" wheels will clear a Wilwood kit, not sure about an AEM kit
Old Oct 29, 2005 | 01:57 PM
80884's Avatar
Default Re: Big brakes + 15" wheels......Help? (EtherGhost)
Thanks man, i'll look into them. I'll look into the wilwood kit also just to see what size the rotor is.
Old Nov 1, 2005 | 07:50 AM
handofgod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EtherGhost &raquo;</TD></TR><TR><TD CLASS="quote">Team Dynamics Pro-Race 1 15" wheels will clear a Wilwood kit, not sure about an AEM kit</TD></TR></TABLE>
Fastbrakes.com will sell you both the wheel and the brake kit. Ask them about fit.
wEaK Squad *ATL*
Jan 8, 2012 03:42 PM
LightningTeg
Aug 19, 2011 06:25 PM
BsmoothR
Jul 22, 2006 03:18 PM
TurboJesse
Jan 9, 2004 12:07 AM
Pinhead
Apr 11, 2002 03:53 PM
