Static Fuel Pressure...whats it suppose to be set at?( 97 Del Sol D16Y8)
i believe it is 35 psi with vacuum hose on and 40-42 psi vacuum hose off......atleast thats what i remember it being when i installed the gauge before i did the B&M regulatro......if you have I/h/e an extra 2 psi wont hurt
From mr. helms:
3. Start the engine*. Measure the fuel pressure with
the engine idling and the vacuum hose of the fuel
pressure regulator disconnected from the fuel pressure
regulator and pinched.
Pressure should be:
270 - 320 kPa (2.8 - 3.3 kgf/cm2, 40 - 47 psi)
4. Reconnect vacuum hose to the fuel pressure regulator.
Pressure should be:
220 - 250 kPa (2.2 - 2.5 kgf/cm2, 31 - 36 psi)
Pressure should be:
Pressure should be:
Mr.EM1
Jan 6, 2005 11:17 AM
potatostix
Apr 11, 2004 12:33 PM
TakaIntegra
Jun 18, 2002 06:30 AM
